US-based site having tax problems
  • Thank you received: 13494
12 years 11 months ago #45490
Yes, you can use that plugin in order to calculate the taxes as you want. Also, from HikaShop 1.5.6 you need to turn off the option "display detailed taxes" of the Display tab of the configuration when using that plugin
12 years 11 months ago #45510
I use hikashop business 1.5.7, turned off the option: display detailed taxes, and I use this plugin.
Result: Tax contain only shipping tax.
It's not content the product's tax.
If i turn off the plugin, i see the product's tax, but the hikashop round the value.
Last edit: 12 years 11 months ago by palmaid.
12 years 11 months ago #45614
We don't have the problem on our end.
Could you give an example of your configuration/tax rules/product and the result on the checkout so that we can try to reproduce the problem ?
12 years 11 months ago #46299
Hi!
I wrote you privat message about 1 week age, but maybe, you don't read this, so I wrote here:
My sample website: cegesruhazat.hu/curves2/administrator
username/password: ******
If I turn on this plugin, it will not the product's tax.
Last edit: 12 years 11 months ago by nicolas.
12 years 11 months ago #46304
Here is a new version of the plugin which should help in your case.
(I have uploaded a non working version of the plugin on your test website which has an error. Just change the file name via FTP in order to remove the error and upload that new version)
12 years 11 months ago #46305
Thanks, its working :)
