Having problems saving product mages
13 years 8 months ago - 13 years 8 months ago #85857
by rowby
Having problems saving product mages was created by rowby
Hello Using Joomla 3.0.2
Hikashop version : 2.0.0
I'm having problems getting the images to save for the products.
I'll upload an image. Save the image. Sometimes I see duplicate images appear after I do the upload. Sometimes, after saving the product The iamage disappears and only the barcode reappears.
If it helps I'm using images from an earlier install, that I saved to my local compuer. I'm taking the images from the old /public_html/media/com_hikashop/upload folder. However I don't see why that should make a difference. Permissions for the new site's upload folder are 755
Any thoughts?
Rowby
Any thoughts?
Rowby
Last edit: 13 years 8 months ago by rowby.
13 years 8 months ago #85916
by Xavier
Replied by Xavier on topic Having problems saving product mages
Can you try with the permission 775 ?
The image system changed, and will be available in the next release.
Time to create page: 0.140 seconds
