Products not appear in div (Ja configured)
11 years 9 months ago #91012
Site: www.fonetech.com.br/index.php/pt/loja-virtual
Hello, I am having problems
I am not able to configure the layout
I put in configurations
Content Type: Product
Type of layout: Div
Number of Columns: 4
Number of items: 10
More on this Site Layout not showing columns
11 years 9 months ago #91103
You have to click on the link "Options for the 'Associated [...] 326'", then change the number of columns in the module parameters.
11 years 9 months ago #91246
remains so after configured
the same way
not order the columns in the grid
the same way
11 years 9 months ago #91391
It should be ok, are you sure that you are editing the good menu and associated module for you listing ?
If it is, could you give us a backend access ?
The following user(s) said Thank You: phsoares
11 years 9 months ago #91433
sure, I'll send the password for inbox
  • Thank you received: 13379
11 years 9 months ago #91599
The issue is that you're activated the bootstrap design option of the configuration of HikaShop but that your website template does not support bootstrap design. Please deactivate that option or use a bootstrap template and that will work.
11 years 9 months ago #91727
thank you
problem Solved
Time to create page: 0.100 seconds
