Another Control Panel display problem
12 years 9 months ago - 12 years 9 months ago #137500 by shinehaid
I'm having an apparent display conflict between my template and the way that Hikashop displays elements in the control panel (see attached file). Is there anyway to change the background of the affected areas to a different one?
Thanks in advance,
Mark
Last edit: 12 years 9 months ago by shinehaid.
12 years 9 months ago #137533 by Mohamed Thelji
Sure using some CSS code will probably do the job.
12 years 9 months ago #137563 by shinehaid
Mohamed,
Thanks, but I'm not a CSS programmer. In fact, I'm not a programmer beyond some VERY simple stuff. I'm able to see the elements in Firebug and change them but have no idea how or what to edit in order to make this permanent.
Mark
12 years 9 months ago #137574 by Mohamed Thelji
Ok, so can you give me a link to your website so that I can directly check it ?
12 years 9 months ago #137605 by Mohamed Thelji
The CSS code that is causing you this issue is the code from the file "media/com_hikashop/css/frontend_default.css" :
.hikashop_carts .row0, .hikashop_orders .row0 { background-color: #F0F0F0; }
you'll just have to change the background-color property.
The following user(s) said Thank You: shinehaid
12 years 9 months ago #137616 by shinehaid
Got it. Thanks again Mohamed, you've been great!
Time to create page: 0.322 seconds
