Return requests and transactions system for customers
9 years 7 months ago #266114 by progfloyd
Is there a way to let customers can do a return requests of the order?
Just like the Opencart do.
After the customer returns the order, we can make the returned money to their transactions system.
Then once he buying something next time, he can use the money of transactions system again.
Thank you.
9 years 7 months ago #266135 by nicolas
There is no automated way for that.
You can do it manually: The customer uses your contact form to request that. Then, you cancel the order, and you add a coupon of that value and you give the code to the customer. Or you configure the points system and you add the equivalent in points to the user account's points.
9 years 7 months ago #266139 by progfloyd
OK.Thank you very much.
Does it may be a feature in the future version. It may be useful.:)
9 years 7 months ago #266147 by nicolas
We're thinking about some returns function for the future. But we're not clear yet as to how to do it.
The problem is that people want it in different ways.
Some just want a contact button which will link the contact request with the order.
Some will want it to process a refund automatically.
Some will want it to be able to select some products of the order with the request.
Some will want it to create a coupon.
Some will want it to gain points.
Some might want something else.
And then you have to take into account the different combinations of all this.
And thus, having something automatic that you can configure to handle the different cases gets tricky really rapidly.
9 years 7 months ago #266297 by progfloyd
Hmm...It does a hard job. Thank you all.
Waiting for this function. :)
9 years 7 months ago - 9 years 7 months ago #266491 by progfloyd
For another question.
If I want to let customers who can check their own points on the user control panel,
how can I write the php code to make it?
Thank you.
Last edit: 9 years 7 months ago by progfloyd.
9 years 7 months ago #266493 by Jerome
Which points are you talking about exactely ?
9 years 7 months ago #266659 by progfloyd
Sorry, I am talking about the points system.
And I want to let customers can check how many points they have on the frontend (user control panel).
Thank you.
9 years 7 months ago #266663 by nicolas
You can use such code :
<?php $user = hikashop_loadUser(true); echo $user->user_points; ?>
If you want to have it on the user control panel, you can add that code in the file "cpanel" that you can edit via the menu Display>Views.
The following user(s) said Thank You: progfloyd
6 years 7 months ago #317744 by n00bster
are there any news about a "returns function"?
6 years 7 months ago #317750 by nicolas
No it's still on our todo list.
As I said 3 years ago, different merchants will want to handle returns differently so it's not easy to have a one size fit all solution.
Also, we worked on other things that were more requested, more concrete, or for which someone paid us to work on.
