Transparent background for Categories & Products??
15 years 3 months ago #20962 by squeakstar
Hey, whilst it is obvious how to change the background colour for the category and item images, what is not so obvious is how I can just show the thumbnail for those items and not show the background tile through at all. Could some kind soul give me a pointer as how to accomplish this??? Thanks!!
15 years 3 months ago #20973 by nicolas
If you empty the background color field and save the options of your menu/module, the background should become transparent.
15 years 3 months ago #20975 by squeakstar
That simple - doh. Many thanks! :laugh:
15 years 3 months ago #21059 by squeakstar
One more thing, sorry - whilst I've successfully applied what we've discussed already to categories, i find that actual product's thumbnails still have a white box surrounding the item - where are these options for actual products div background?
Also, is it possible to create a default setting like i have found for categories in the options?
thankyou!
15 years 3 months ago #21060 by nicolas
The default settings for products and categories are the same, in the tab Display of the configuration.
For your products, you should edit the hikashop options of the associated module of your menu.
15 years 3 months ago #21063 by squeakstar
found it, it's in the associated content module, but even when i remove the background colour i have a white border with rounded corners i want rid!!! Even if the box corner style is no to rounded corners i see a rounded corner border :(
15 years 3 months ago - 15 years 3 months ago #21065 by nicolas
Yes. The main menu color takes over when you don't specify a color for an associated module. If you remove the color of the main menu you should not have any color for the modules where you removed the color.
Note that it's always possible to override the background color in CSS... With the CSS below you can remove all the backgrounds everywhere on the front end of HikaShop:
div.hikashop_subcontainer {
background-color: transparent !important;
Last edit: 15 years 3 months ago by nicolas.
15 years 3 months ago #21067 by squeakstar
here's an example!
background: (no value) image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/Capture-20110711.PNG
15 years 3 months ago #21069 by squeakstar
er, sorry, would this acheive what i'm after then ? If so where is this setting exactly?
or would the css you describe achieve what i'm after completely and forever more by default?
cheers!
15 years 3 months ago #21072 by nicolas
Yes, the CSS would solve the problem and never display the background anymore on any listing.
15 years 3 months ago #21073 by squeakstar
cool, and do i add the suggested css to my template's css file or one i may find in HikaShop directory?
thank you!
15 years 3 months ago #21074 by nicolas
You can put it in your template's CSS.
15 years 3 months ago #21206 by squeakstar
done that - yay.
I also managed to remove the border from the subcategories by changing the border value to this:
div.hikashop_products div.hikashop_subcontainer{
border: 0px solid;
in /media/com_hikashop/css/frontend_default.css
12 years 5 months ago - 12 years 5 months ago #155811 by vinitbajaj
Hi i am recieving the same issue in the category thumbnail after upgrading to your latest version, the category thumbnails show a white background earlier they were appearing transparent now they are appearing with the white background, i added the css code it made the inner container transparent instead of thumbnail pic., please find attached the screenshot of the page.
Where as in Products listing the products appear fine. Can you please tell if i have to switch off some setting.
Last edit: 12 years 5 months ago by vinitbajaj.
12 years 5 months ago #155817 by Xavier
In you case the problem is the generated thumbnail. Thanks to change the settings of thumbnail generation in Configuration > Main > Images.
Time to create page: 0.254 seconds
