Problems With Steps in Checkout Workflow
13 years 2 months ago #26014
Im using Hikashop 1.5.2 with Joomla 1.6
I am using Hikashop purely for the checkout facility to order documents that will be manually sent out. The products are zero in price also the shipping method (which i dont really need) is set mto zero price eg free shipping
When I first setup the shop all was working fine but somewhere along the line the checkout steps don't seem to work. The problem is I cannot get to the end of the checkout process.
I have the following settings:
Checkout workflow: login_address_shipping_payment_cart_status_fields_confirm,end
Payment method: HikaShop collect on delivery payment plugin
Shipping method: HikaShop manual shipping plugin
I have tried various permutations of the settings but cannot get this to work.
Has anyone any ideas what I am doing wrong??
The shop is at: test.andonfreres.co.uk/index.php?option=...t=listing&Itemid=140
clicking on 'Request CA' will add the item to the basket
  • Thank you received: 13378
13 years 2 months ago #26036
If you don't need shipping and payment, why not just remove both views from the checkout workflow ?
That will avoid that your checkout gets stuck because of the way you configured payment or shipping methods.
So you could have this:
login_address_cart_status_fields_confirm,end
13 years 2 months ago #26198
Thanks for your reply. I should have said that I have tried without payment and shipping in the workflow.
I have entered login_address_cart_status_fields_confirm,end as you suggested but I still have the same problem when I click next I get the same page.
Example urls
when on this url: /index.php?option=com_hikashop&ctrl=checkout
I click next and it goes to: /index.php?option=com_hikashop&ctrl=checkout&task=step&step=1
but I see the same page. Clicking next on this page just reloads the same page.
I have tried this with the payment and shipping modules enabled and disabled and I get the same as described above.
I have enabled the checkout progress bar but that just shows login and end
13 years 2 months ago #26205
First, you should update HikaShop. There are some messages which should be displayed if there is a reason why the checkout doesn't let you finish.
If you don't see any error message, it might be because your template does not support joomla messages:
www.hikashop.com/en/support/documentatio...tibility-issues.html
13 years 2 months ago #26209
I already have the <jdoc:include type="message" /> in the template just above <jdoc:include type="component" />
I just upgraded to Hikashop Essential 1.5.4 but now get the following error messages when trying to access hikashop in the frontend :(
Warning: include_once(/home/s/t/stopnokia/web/public_html/administrator/components/com_hikashop/classes/filter.php) [function.include-once]: failed to open stream: No such file or directory in /home/s/t/stopnokia/web/public_html/administrator/components/com_hikashop/helpers/helper.php on line 760
Warning: include_once() [function.include]: Failed opening '/home/s/t/stopnokia/web/public_html/administrator/components/com_hikashop/classes/filter.php' for inclusion (include_path='.:/usr/share/php:/usr/share/pear') in /home/s/t/stopnokia/web/public_html/administrator/components/com_hikashop/helpers/helper.php on line 760
Fatal error: Call to a member function getFilters() on a non-object in /home/s/t/stopnokia/web/public_html/components/com_hikashop/views/product/view.html.php on line 99
13 years 2 months ago #26211
Please download again the installation package from our website and install it again. That should solve these errors.
13 years 2 months ago #26218
Ok I have re installed and hikashop is back up again. I am still experiencing the same problems as described above. I don't see any error messages.
13 years 2 months ago #26230
Could you give a link to your shop so that we can see the problem ?
13 years 2 months ago #26288
13 years 2 months ago #26294
Please make sure that you have the "confirm" step in your checkout workflow option. It seems to be missing from your checkout. If you have it, please provide a back end access to your website so that we can check your settings.
13 years 2 months ago #26311
Before the upgrade I entered 'login_address_cart_status_fields_confirm,end' in the checkout workflow. However, in this latest version 1.5.4 I notice the input area for the workflow has changed and confirm is not present....there is not an icon for 'confirm' so I cannot add it.
Also, just noticed when in the admin configuration I am still getting the following error:
Warning: include_once(/home/s/t/stopnokia/web/public_html/administrator/components/com_hikashop/types/filter_button_position.php) [function.include-once]: failed to open stream: No such file or directory in /home/s/t/stopnokia/web/public_html/administrator/components/com_hikashop/helpers/helper.php on line 760
Warning: include_once() [function.include]: Failed opening '/home/s/t/stopnokia/web/public_html/administrator/components/com_hikashop/types/filter_button_position.php' for inclusion (include_path='.:/usr/share/php:/usr/share/pear') in /home/s/t/stopnokia/web/public_html/administrator/components/com_hikashop/helpers/helper.php on line 760
How do I send you login details?
13 years 2 months ago #26320
That's the problem.
We've put up a new built of the 1.5.4 release. Please download it again from our website and install it. That should allow you to set the confirm step in your checkout workflow and will remove the other error.
13 years 1 month ago #26349
Hi, re-installed the latest 1.5.4 release. I now see the confirm in the checkout workflow. However, I am still experiencing the same problems as before as in i cannot get to the end of the checkout.
13 years 1 month ago #26357
Update: I removed 'confirm' from the workflow and tried to add it back to the workflow but when I save the config it disappears.
13 years 1 month ago #26374
I don't have that problem on joomla 1.6
Would it be related to your browser maybe ? Could you try with another one ?
13 years 1 month ago #26379
I use firefox and have just tried IE8 and I still cannot add confirm back into the workflow :(
13 years 1 month ago #26403
Could you try to add the confirm in the first step of the checkout workflow, save, and then move it to your step. That works on our end, while after some attempts to reproduce the problem, adding the confirm step directly in the last step didn't.
13 years 1 month ago #26435
Yes I have managed to add the confirm back to the workflow using your instructions above.
I am still experiencing the same problem....cannot get to the end of the checkout
13 years 1 month ago #26458
Please provide a back end access to your website so that we can check on the problem.
13 years 1 month ago #26525
I have sent details via the contact form
