Problem with product Picture
13 years 10 months ago #4672
Hi how i can center the immage of the product box or is possible that the picture fit the box without white border ?
I attach one immage so you can understund better
http://www.scmarconi.it/images/zzzzImmagine111.BMP
  • Thank you received: 13372
13 years 10 months ago #4679
The problem is that the display is handled by the joomla modal popup library and it renders differently depending on the browser and since it's an image directly in an iframe you can't apply CSS to it. What you could try is to personnalize the modal popup chrome in your template CSS file.
For example, you could change the white background to black by adding the CSS code below to your template CSS file:
#sbox-content {
 background-color: #000000;
13 years 10 months ago #4684
Sorry friend I'm new ...where i can found the css
many thanks for all help !
13 years 10 months ago #4685
This tutorial explains how to modify a joomla template, including how to edit your CSS: www.ultijoomla.com/blog/How-To-Edit-Joom...emplates-part-1.html
