change per unit into per set, per length, per reel
14 years 4 months ago #51395
we are planing to sell products with a hikashop 2.5.
in the product-mask i haven't the possibility to change the phrase "per unit" after the price into one of the other terms mentioned above. A simple translation isn't usefull, because we sell different things per unit, per set, per length (per meter) ot per reel. So is there a possibility to adjust the term seperately for every product?
14 years 4 months ago #51475
Hi cobinet,
A way to do that is:
Create a "Custom field" in Hikashop > Display > Custom fields with the table "Product" with the title, for example: "product_per";
In your product configuration page, add "unit" in the "product_per" field.
Then in Hikashop > Display > Views, edit the view: "product / listing_price.php" in the good template.
Here you can replace:
echo JText::_('PER_UNIT');
To:
					if($this->element->product_per == 'unit'){
And add custom values for your checks: unit / set / lenght / reel ...
The following user(s) said Thank You: cobinet
14 years 3 months ago #51860
I used this Version to solve the Problem:
$mengeneinheit1 = JText::_('PER_UNIT') ;
          foreach($this->fields as $fieldName => $oneExtraField) {
          if(!empty($this->element->$fieldName)){
          if( $this->fieldsClass->show($oneExtraField,$this->element->$fieldName) == 'pro Satz'){
          $mengeneinheit1 = JText::_('per pack');}
          else if( $this->fieldsClass->show($oneExtraField,$this->element->$fieldName) == 'pro Meter'){
               $mengeneinheit1 = JText::_('per meter');}
          else if( $this->fieldsClass->show($oneExtraField,$this->element->$fieldName) == 'pro Rolle'){
               $mengeneinheit1 = JText::_('per reel');}
          echo $mengeneinheit1;
But thre's another Problem.In the product overviews, there is alway mentioned 'PER_UNIT' or my translation 'pro Stück' and not my chosen option (here per_pack). So i need to copy the text in another file, but i coldn't find it. Could you give me a hint.
Here the picture:
Overview
Product Page
Last edit: 14 years 3 months ago by cobinet.
14 years 3 months ago #51910
Hi cobinet,
For the product overviews you need:
$this->row->product_per == 'unit'
if($this->element->product_per == 'unit' || $this->row->product_per == 'unit'){
Last edit: 14 years 3 months ago by Xavier.
14 years 3 months ago #53602
I'm a bit stuck with this, I try create a custom field, but the Table option is set to "address" can't change it too "Product" and add as per Xaviers instructions.
Also I am looking to create instead of the $14.95 each to $14.95 per page
Sorry but getting a bit lost creating this.
Sorry fixed!, got it via the Configuration, languages file, edited that and voila, per page pops up ;)
Last edit: 14 years 3 months ago by Afrosaxon.
  • arens
13 years 10 months ago #73836
Any issue.
How too change order of " per unit" for before the price??
Ex: per unit 345 €
tx
13 years 10 months ago #73984
You can override the translation of: "PRICE_BEGINNING" to set: PRICE_BEGINNING="per unit". and the translation of: "PER_UNIT" to PER_UNIT=""
  • arens
13 years 10 months ago #73995
Thx Xavier
I solved but i have aproblem in page Checkout appear "precio" in resume products.
See attacha capture
Attachment not found
13 years 10 months ago #74121
You can edit the view "product / listing_price" and add a span tag around the text "echo JText::('PRICE_BEGINNING');" like:
echo "<span class='hika_price_beginning'>;
echo "</span>";
And then add a property in the frontend css file like:
.hikashop_checkout_cart .hika_price_beginning{
    display: none;
  • arens
13 years 10 months ago #74257
Hi Xavier,
i put the code , but a error syntax,
the error:
arse error: syntax error, unexpected '/' in
i write this:
echo '<span class="hika_price_beginning">'.JText::_('PRICE_BEGINNING');
But no dissappear .
The text appear , in the PDF, mail etc.. all
13 years 10 months ago #74261
Yes I forgot a double quote, try this:
echo "<span class='hika_price_beginning'>".JText::_('PRICE_BEGINNING')."</span>";
  • arens
13 years 10 months ago #74266
I put the code bit no dissapear "Precio" :(
13 years 10 months ago #74269
Do you have set the CSS property ?
Could you give a link to your website ?
  • arens
13 years 10 months ago #74270
i put the code in:
checkout / listing_price.php
And dissappear!!
is correct?
i need dissapear in Pdf and mails how too file modified??
13 years 10 months ago #74523
All the views where "PRICE_BEGINNING" is present are:
"checkout / listing_price", "checkout / shipping", "product / listing_price".
13 years 4 months ago #101359
To expand a bit more on the original problem I am having trouble making this change show in the category listing - I assume there is a file I have to add this code to within the category view? I just can't seem to find which one to change.
So far I have added this code:
if($this->element->product_per == '' || $this->row->product_per == ''){
else{
echo $this->element->product_per;
to the file "product / listing_price"
I still need this change to show on the category listing; goo.gl/4ZFzg
Thank you for your help.
13 years 4 months ago #101589
What is the var $this->element->product_per ? a Custom field.
If not, you have to create a custom field with this name.
13 years 4 months ago #101598
Xavier wrote: Hi cobinet,
Yes I have created the custom field 'product_per' and I used the code from your post above.
Thanks again for your help.
  • Thank you received: 8
6 years 5 months ago #317553
I found this topic to do what I want to do, namely to be able to change the sales unit according to the categories or according to a choice.
but the problem is that this explanation dates from old version of hikashop and no longer goes.
can you tell us how to do the same operation with hikashop verion 4?
I thank you in advance !
  • Thank you received: 14222
6 years 5 months ago #317556
The exact code indeed changed but the principle is still valid.
In the file product / listing_price.php
You have that code:
echo '<span class="hikashop_product_price_per_unit">'.JText::_('PER_UNIT').'</span>';
and you can still replace it with :
where "product_per" is the column name of the custom product field where you've selected / entered the text to have instead of "per unit".
Time to create page: 0.140 seconds
