Problems displaying 2 colums per page.
13 years 10 months ago #5385
I have tried to reassociate the menu items and went into product id to change the display. Clearing cache and everything else too. I've changed the default values in the main hika config's. no luck.
please help!
  • Thank you received: 13372
13 years 10 months ago #5386
The default parameters in the hikashop config are just default options for new modules and menus. For existing ones, you need to edit their options. You can edit your menus/modules hikashop options via the "hikashop options" link in your modules/menus options or access them directly via the menu Display->Content menus and Display->Content modules.
13 years 10 months ago #5389
I've done that.It isn;t working. Everything is still displaying as one column aligned to the left side of the pagecontent area.
13 years 10 months ago #5390
I've cleared page and hika cache and browser cache.
It's like that whole parameter/valueis commented out,and I don'tknow where it is or it's working string.
I'm completely baffled
Last edit: 13 years 10 months ago by JWeb5.
13 years 10 months ago #5391
Could you give a link to your page where you have that 1 column problem ?
13 years 10 months ago #5392
aquatic-exotics.net/index.php?option=com...ut=listing&Itemid=98
all conteht pages have thesame display problem
13 years 10 months ago #5394
I see two columns on that page.
You have the same problem as explained on that thread I suppose because your looking at your page with IE:
www.hikashop.com/en/support/forum/2-gene...-product-layout.html
That bug is fixed in the latest version of Hikashop so if you update it should go away.
13 years 10 months ago #5395
Thank you!
