Products not showing on categories.
13 years 9 months ago #7117
Using the search function on the front end the products are found.
I am also having issues with images being shown.
  • Thank you received: 13372
13 years 9 months ago #7122
And are you sure that your CSV is correct for those products ?
Could you send us your CSV so that we can have a look at it ? You can send it to This email address is being protected from spambots. You need JavaScript enabled to view it.
