Add to cart link. Ajax or Stay same page POSSIBLE?
10 years 7 months ago #228247
Thank you
I used latest version of hikashop. How can do it?
  • Thank you received: 4078
10 years 7 months ago #228255
With that kind of code ; you cannot.
But it will be possible in HikaShop 3.
You have the latest version of HikaShop ; so you have the version 2.6.1
So you do not have HikaShop 3 ; which is fully logical because we are still working on that development.
The following user(s) said Thank You: kaya
10 years 7 months ago #228301
Thank you
I think I can get cart id by this code
$app->getUserState( HIKASHOP_COMPONENT.'.cart_id', 0, 'int' );
and remove product from my cart with prodct_id and cart id by using ajax post method.
  • Thank you received: 14222
10 years 7 months ago #228355
As this post says www.hikashop.com/forum/4-how-to/8572-add...-possible.html#27582 you can set the quantity to 0 in the add to cart URL in order to reset the quantity to 0 for the product in the cart.
