product delete problem during checkout
11 years 9 months ago #90330
Hi!
After I’ve updated hikashop to 2.1 version I am having this problem:
- add to cart for example two products
- go to checkout and I decide to delete one of the items on my checkout cart
- after that even though I still have one item left on my cart the system alerts that the cart is empty
I did not have this problem before the update.
Please try it yourself and you’ll see what I mean:
smartshop-ks.com/jo
What should I do?
11 years 9 months ago #90551
Are you using the Joomla cache, or a cache component ? Try to disable it.
11 years 9 months ago #90618
As I mentioned I didn’t have this problem before hikashop update. I haven’t done any changes on cache settings and as far as I know there is no other cache component.
Please see the attachment.
Last edit: 11 years 9 months ago by mkosova-alija.
  • Thank you received: 4028
11 years 9 months ago #90971
It could be a problem with the "currentUrl" like explain in this thread:
www.hikashop.com/en/forum/3-bug-report/7...ation-bug.html#90837
