Cart module strange
  • Thank you received: 5
11 years 7 months ago #97137
I want to use the Hikashop cart module but can't get it to work as expected. No matter what settings I use, the frontend shows like the attached image.
Can somebody tell me what is going wrong and what I can do to solve it.
Sjaak
  • Thank you received: 13378
11 years 7 months ago #97144
Go in the joomla configuration and set the "error reporting" option to "none" and that will correct that.
11 years 7 months ago #97151
Thank you Nicolas. This helped.
Sjaak
11 years 7 months ago #97303
Mmm, well not totally,
When I browse my website using the normal menu structure the shopping cart looks normal without error.
When I browse my shop categories via the category listing module the shopping cart sill shows the error. I get the idea something is wrong with the category listing module. I have another topic in this forum about that module. "Hikashop content module not working as expected". Is it wise to use that module?
Sjaak
11 years 7 months ago #97331
Hi Sjaak,
Can you give me a link to your "shop categories" module, then I'll maybe see what the problem is.
11 years 7 months ago #97335
Hi Mohamed,
My new website and shop is not yet published. It's a bit hard to show it now. Then I would need to give you backend access. Not a problem for me but certainly not something to share on this forum.
Can you contact me off forum?
Sjaak
11 years 7 months ago #97360
Sure, you can send it to me through Private Message.
11 years 7 months ago #97557
I checked your website but didn't see any error.
11 years 7 months ago #97568
Hi Nicolas/Mohamed,
Can it have something to do with this forumtopic: 'Hikashop content module not working as expected'?
Are topics related?
Sjaak
11 years 7 months ago #97647
Yes I think it's related. I have answered on the other topic ;)
Time to create page: 0.102 seconds
