Quantity box in checkout cart for option products
  • Thank you received: 4
1 year 9 months ago #348816
-- url of the page with the problem -- : dev.infinitybrewing.uk/checkout
-- HikaShop version -- : 4.7.0
-- Joomla version -- : 3.10.11
-- PHP version -- : 8.0
Hi, I have some option products on my site. In the cart layout page the quantity box shows, but in the checkout layout with a cart on you cannot.
How can I change the checkout cart to have an editable quantity?
Last edit: 1 year 9 months ago by infinityb.
  • Thank you received: 13372
1 year 9 months ago #348818
Check the "quantity input" setting of the product you're using as an option. If it's set to "no", then the quantity input field won't display on the product page of that product, and also won't on the checkout.
I suppose you don't have the behavior on the cart page because it has been customized based on an old version of HikaShop where the cart page didn't support the "quantity input" setting of the products and thus always displays the quantity input field.
The following user(s) said Thank You: infinityb
1 year 9 months ago #348830
It was the 'quantity option' on the product page, thanks! Forgot I switched that off.
Time to create page: 0.041 seconds
