Best way to Selectively No Index Some Products
11 years 7 months ago #189801 by sison2466
-- url of the page with the problem -- : iheartsin.com
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.3.29
I keep reading articles that I should change the product descriptions that I get from manufacturers, as I could be SEO penalized due to duplicate content.
I am in the process of rewriting the most popular products, but for items that I don't want to invest the time in rewriting, articles are suggesting I set them up as no index. What is the easiest way to set some, but not all of the product as no index?
Also, for Hikamarket, if the product is listed on the Vendor page and on the main site, is that going to be considered duplicate content as well?
11 years 7 months ago #189805 by nicolas
Create a custom product field via the menu display>Custom fields with two values rel="nofollow" and empty.
Then, in your products that you don't want to index, select the rel="nofollow" choice for the custom field.
In the file "listing_img_title" of the view "product" (supposing that you're using the "image and title" item layout), just change the line:
<a href="<?php echo $link;?>" title="<?php echo $this->escape($this->row->product_name); ?>">
<a href="<?php echo $link;?>" title="<?php echo $this->escape($this->row->product_name); ?>" <?php echo $this->row->FIELD;?>>
where FIELD should be replaced by the column name of your custom field.
2. Pages which are accessed after a login/registration are not indexed by Google so no problem there.
The following user(s) said Thank You: levelup
11 years 6 months ago - 11 years 6 months ago #195789 by sison2466
If I paste the code below into the the file, I get a 404. When you say using a "image and title" item layout, where do I check that setting?
<a href="<?php echo $link;?>" title="<?php echo $this->escape($this->row->product_name); ?>" <?php echo $this->row->nofollow;?>>
To clarify, "nofollow" is the name of my column.
Last edit: 11 years 6 months ago by sison2466.
11 years 6 months ago #195793 by Jerome
A 404 ? Would it be possible to have an example ?
Your custom field "nofollow" should contain a full html tag, like
nofollow="nofollow"
otherwise it can break the HTML content and provide a non-working link.
It's the single idea I got.
11 years 6 months ago #195895 by sison2466
I am not sure I understand. I'll explain what I did. If that doesn't work, I'll set up a test server and make the changes so it will 404.
I have a custom field labeled "No Index" associated with a column name for my product called "nofollow"
I set the default value to equal rel="nofollow" (pic attached)
I then go to the listing_img_title file of PRODUCT under DISPLAY->VIEWS for the front end of my specific template
I replace
with
should the nofollow above be No Index?
11 years 6 months ago #195911 by nicolas
I don't see why that change would generate a 404 error since you don't change the href attribute of the link.
On top of that, your modification is correct so it should work fine.
The 404 error must come from something else.
Do you mean that if you remove the modification you don't get the 404 and if you add it back you get it again ?
That would be really strange.
11 years 6 months ago #196216 by sison2466
I'm an idiot...not sure what I did differently, but it's working now. Sorry to waste your time.
One last question. Anyway to make sure that I set up the "nofollow" to actually working properly?
11 years 6 months ago #196222 by nicolas
Right click on the link and click on the "inspect element" (or something similar) choice and that will open your browser's debugger and you'll see the HTML of the link. There, see if you get the rel="nofollow" added to the link and you'll see if that works or not.
11 years 6 months ago #196338 by sison2466
Doesn't look like what I did worked. I see "nofollow" for some social links, but not a product.
view-source:http://www.modelmisconduct.com/index.php/shop/product/hosiery-1565
11 years 5 months ago #196731 by sison2466
I just wanted to follow up on my prior post, as it does not look like the changes I made are working.
11 years 5 months ago #196781 by sison2466
Also stupid question, but if the purpose is to not receive penalty for duplicate content, don't I want "noindex", rather than "nofollow"?
11 years 5 months ago #196869 by Jerome
You're editing the view "listing_img_title", right ?
So I don't understand why are you giving a link to a product page which does not contains any product listing module ; the modification you made won't be visible in the product page.
11 years 5 months ago - 11 years 5 months ago #196944 by sison2466
Hi Jerome,
Thank you for responding. Perhaps I am unclear.
The content (specifically the product description) that I want to control whether is index/crawled by search engines are on the product page like the one below.
My question is what is the best way to no have some,but no all my products not get crawled?
If I need to clarify further, please let me know.
Marco
Last edit: 11 years 5 months ago by sison2466.
11 years 5 months ago #196946 by Jerome
See : developers.google.com/webmasters/control...docs/robots_meta_tag
About the duplicate content, use Canonical url
See : moz.com/learn/seo/duplicate-content
11 years 5 months ago #197013 by sison2466
Hi Jerome,
My Question is if there is a way to set <meta name="robots" content="noindex" /> on individual products? Perhaps using the method you guys suggested with custom fields?
11 years 5 months ago #197094 by Xavier
To add a meta tag on some products, you can indeed use custom product fields, create one for example meta_noindex with a default value set as "false", then in the product edition page change the field value to "true" for the desired products. Don't display it on frontend.
And edit the view "product / show_default", then add code like:
<?php if($this->row->meta_noindex == 'true'){ $doc = JFactory::getDocument(); $doc->addCustomTag( '<meta name="robots" content="noindex" />' ); } ?>
11 years 5 months ago #197493 by sison2466
Just to confirm, if we WANT the product to be indexed/crawled, the the noindex value should = "false"?
11 years 5 months ago #197513 by nicolas
The code Xavier gave you will add the metatag to the page only if the value of the custom field is "true". So if you set anything else in it, including false, it won't add it.
11 years 6 days ago - 11 years 6 days ago #215008 by sison2466
What is the best way to confirm we did this correctly?
I set item 4016 to true
but when I view source, I don't see anything that states noindex
view-source:http://www.modelmisconduct.com/hikashop-menu-for-brands-listing/lacy-satiny-chemise-sexy-after-dark-4016
Last edit: 11 years 6 days ago by sison2466.
11 years 6 days ago #215020 by Jerome
In the code I can read "true" and not "TRUE" ; which are for a code aspect, different strings.
Time to create page: 0.310 seconds
