No response when I click "send a comment"
  • Thank you received: 13533
7 years 1 month ago #289222
Please understand that this error doesn't come from HikaShop but from your template.
You should seek advice with your template provider.
I've already given you a highly probable solution in my previous message.
So you can first try yet. If that doesn't help, you'll have to contact your template provider.
And please don't directly post backend or FTP accesses on a public forum.
If your website get hacked because of that, we won't take responsability for it.
The following user(s) said Thank You: yhshih
7 years 1 month ago #289282
Thank you for reminding that. I will contact the template provider.
Thanks again.
7 years 1 month ago #289685
I found the culprit. I renamed one by one and found the listing.php was the reason that the page showed 404 error.
Thanks anyway.
7 years 1 month ago #289692
Thank you for your feedback !
Best regards,
Mohamed Thelji.
