Products Published for same day not availble
  • Thank you received: 5
13 years 11 months ago #2829
Just a Minor one here but if you try to publish a product for the current day it displays the 'Product not available until' Message below.
Publish it a day earlier and she appears as per normal.
Just a minor bug I have noticed.
Last edit: 13 years 11 months ago by reace.
  • Thank you received: 13372
13 years 11 months ago #2846
Concerning the published date being shifted from a day (probably few hours), are you sure it's not because you don't have the good timezone set in the configuration of joomla ? HikaShop uses the excat same way of storing and checking the dates as acymailing which we are sure is storing and checking dates properly since it has been out for over 1 year now. So I highly doubt that there would be any bug in there.
Concerning the display of the date at that place, there is indeed an issue. It comes from a typo in the translation file:
ITEM_SOLD_ON_DATE="This item will be sold starting on %"
It should be:
ITEM_SOLD_ON_DATE="This item will be sold starting on %s"
You can change that in the configuration under the tab languages. We will fix that in all the translation files for next release so that other users also get it fixed.
13 years 11 months ago #2867
As Per Usual I think once Again you are correct;
Global Settings > Server > Locale;
So I will correct that , also noticed something that Ive never paid much attention to before in Joomla itself which has always annoyed me and that's the Path to images lol , images > Stories (can be Changed to what ever folder) cool.
I will make the Change for the other minor type %s shortly.
btw which file do I make this change in ? Thanks.
Thanks Again.
:woohoo:
