Related products module
14 years 2 weeks ago #1221
I have another issue for you, sorry :).
I created a module at the left part of the page. This module has been configurated to display Related products to the ones which are being shown.
I set it up this way:
Sub elements filter = all sub elements
Parent Category = the same as products involved here.
Content on product page = related products
Also, i related two products between them, bidirectionally. "Camisa verde" is related to "pantalon Rojo" and vice versa (I don´t know it this is strictly necessary).
You can see how in both products page, the other has not been shown at the module.
shoptest.avaray.com/es/component/hikasho...o/category_pathway-0
shoptest.avaray.com/es/component/hikasho...e/category_pathway-0
To make things a bit more complicated, if you go to the site main page, you will find the Related products module fullfilled with products.... related to what?
I guess that i have lost something in my way here :D
Last edit: 14 years 2 weeks ago by Avaray. Reason: Sintaxys
  • Thank you received: 13372
14 years 2 weeks ago #1224
You need to have the content synchronization option to yes. Maybe that could explain the problem ?
For the fact that the module displays stuff on other pages, well that's the normal behavior of the module. When you don't display a product page, the module displays the elements of the category selected in the options as parent category. If you don't want it to do that, just put there a category with nothing in it. Otherwise, put the module in the "under the product page" option so that it's displayed only there.
14 years 2 weeks ago #1226
If you refer to "Synchronize with currently
displayed item when possible", it was on "yes" already.
14 years 2 weeks ago #1230
There seems to be a bug in the query loading the related products when the ordering column is selected and that the random option is turned off in the options of the module.
If you change the code
$on = ' ON a.product_related_id=b.product_id';
by the code
									if($this->params->get('product_order')=='ordering'){
										$pageInfo->filter->order->value = '';
in the file components/com_hikashop/views/product/view.html.php near line 55, that should solve the problem.
14 years 2 weeks ago #1231
In this line the code is other. Very similar, but another one:
$on = ' ON b.product_related_id=a.
The "a" and "b" variables (or whatever they are) are misplaced.
Please, confirm your fix. I have no idea about programming. :)
14 years 2 weeks ago #1232
I confirm that the modification is the good one even when a and b are inverted (a bug which was corrected by the latest version yesterday).
14 years 2 weeks ago #1235
Again, an excellent support.
I am starting to feel myself as an official Hikashop tester :D.
