Frontend module to add/edit products & categories
12 years 10 months ago #37365
Request for a frontend module to add/edit products & categories. So we don't have to provide admin access to client for this purpose.
  • Thank you received: 13379
12 years 9 months ago #37519
We're actually working on a solution for that. We should have it ready in a few months.
The following user(s) said Thank You: sdhakad
12 years 9 months ago #37567
Thanks, we are waiting for it eagerly...
12 years 8 months ago #41774
Our current project needs this feature. Hope to see this on-board soon ...
12 years 6 months ago #49614
Any news for this feature? :)
Don't wanna put any pressure on you, just to know...
12 years 6 months ago #49615
We're still working it. We're still a few months away from a release.
12 years 6 months ago #49780
This new front end interface, does it allow view/add/edit it tabular form or is it one at a time like the present back end, one at a time is really frustrating, esspecially when you have a table view, its just not editable!
12 years 6 months ago #49901
It will be similar to the back end interface of course.
A mass edition interface is something we want to add in the future but not in the short term as we are focusing on a wishlist system and the multi vendor system at the moment.
12 years 5 months ago #54161
HI.
The seblod integration should made that easy.
Do you have any news about that.
Daniel.
Last edit: 12 years 5 months ago by damendieta.
12 years 5 months ago #54236
I don't know if that will allow you to do that, but that could be possible. We didn't take part in the developement of the seblod integration and didn't hear about it since last month. You should contact seblod directly if you want information/news of it.
The following user(s) said Thank You: tefun
  • Thank you received: 4
12 years 4 weeks ago #73176
i know you are very beasy, and i Don't won't make a pressure on you,
I just want to know, in hikashop 2.0 will be this modification in future? or in 1.6 in future?
I want make catalog with many items, so the fronted editor will be very cool for me)
i know, that every bady want this, but for me important this, that many people will be edit products
Thank you,
Best regards :)
Last edit: 12 years 4 weeks ago by tefun.
12 years 4 weeks ago #73435
Front end edition will be release as a separate extension of HikaShop, like we did for HikaSerial. It will require HikaShop 2.0 minimum. We are currently in beta test for HikaShop 2.0. A few weeks after we release the final version of HikaShop 2.0, we will release that new extension. We are currently wrapping it up and we'll starting testing it soon. It will be released in November or December.
12 years 4 weeks ago #73504
ok, thanks
9 years 6 months ago #201164
Hello.
I d' like to know if you have released the extension?
I am using CB with several different users. I need each user to be able to add/edit his own products in front-end using hikashop. So, I need to know if the extension is released or not? Is it a feature embedded inside hikashop or it should be installed separately like an extension?
In addition, I 'd like the "add to basket/checkout" options get disabled in this case. In fact, I am using hikashop for just displaying products information to other users and not letting them to buy anything. How can I do it for front-end edition?
Can all the above be done by free version or I have to buy commercial version?
Last edit: 9 years 6 months ago by starfish.
  • Thank you received: 4028
9 years 6 months ago #201165
