VOTE AND COMMENT NOT SHOWING UP
12 years 6 months ago #50508
hello guys! I have problem about THE VOTE and comment in the products, i have enabled all the settings about the vote and comment in the configuration area under the VOTE TAB, and also the Parameters for products,
what am i missing here??? this problem makes me crazy! please help! i will attach the images for you to see the settings that i have done so far.
thanks and more power to this awesome plugin! its my first time to use it!
Need a website for your business?
Visit my website and get a FREE QUOTE AND CONSULTATION NOW!
cyberwrathinternetmarketing.com
Last edit: 11 years 9 months ago by jedlarosa.
  • Thank you received: 13379
12 years 6 months ago #50512
Go in the 'Display' tab of the configuration and turn on the Display votes on product page.
The following user(s) said Thank You: jedlarosa
12 years 6 months ago #50514
OH MY GOD!!! DUE TO MY EXCITEMENT TO THIS PLUGIN! i did NOT read it carefully on each of this settings! terribly sorry about that! haha! thanks again sir!
Last edit: 12 years 6 months ago by jedlarosa.
12 years 5 months ago #55888
I have upgraded to the new version of hika business, turned on votes and comments on product pages and still do not see them on the page.
theuncommonlife.com/store
I installed a fresh version of hika on a new site and it works fine.
Any ideas?
12 years 4 months ago #55949
That's probably because you had edited the file "show" or the file "show_default" of the view "product" via the menu Display->Views in order to customize the display of the product page.
Because of that, you are still using the view file of your previous version and you don't have there the code to handle the votes and comments.
You will have to backup your modifications and delete them in the file with the delete icon of the views listing for that view file. Then you should see the votes and comments interface if you configured them properly and you will be able to reapply your modifications to the new view file in order to get back your customization.
The following user(s) said Thank You: jessicapschultz
12 years 4 months ago #56189
thank you for your advice about my modified show.php page, that was the problem. Now I cannot figure why the stars are missing. It shows the number zero and the comment box but the stars are missing :( any clues for this one? theuncommonlife.com/store
12 years 4 months ago #56219
That's a similar problem but with the CSS of HikaShop:
www.hikashop.com/en/forum/4-how-to/43953...ng-system.html#43953
11 years 9 months ago #87859
I also can no longer see stars since updating file for social, instead there is a drop down showing numbers. But I can not access the file you posted here. Please tell me what I need to change in the css.
The stars are showing in other module so I clicked on one and now they show on product. Not sure why.
Last edit: 11 years 9 months ago by dsautelet.
11 years 9 months ago #87926
I think that you had a JavaScript conflict.
Is it working fine now ?
If not, thanks to give us a link to your website.
11 years 9 months ago #88220
Thank you, it seems to be working for the most part now.
Time to create page: 0.113 seconds
