Cart problem
12 years 4 months ago #57880
I need your help.
I installed hikashop starter and my Joomla version is 2.5.6
During my experiments to a test website everything worked smoothly.
But when i installed to my project site a problem was appeared..
When i am clicking "Add to cart" my product is adding to the cart and immediately disapears.
Then when i am clinking to go to my home page the product appear again to the cart.
My website is brownway.gr/index.php/order-form2/category/13-
Any ideas?
Thank you
Last edit: 12 years 4 months ago by mythodia.
12 years 4 months ago #57915
Maybe it's a cache configuration?
But i am not sure. I have disabled cache plugin and from the configuration of joomla the cache is deactivated.
Any ideas?
  • Thank you received: 13374
12 years 4 months ago #57978
It indeed sounds like a caching issue.
You should check your template's options. There are sometimes caching options there too.
