Payment notification does not work with CBuilder
14 years 1 month ago - 14 years 1 month ago #61902
by philgsy
Payment notification does not work with CBuilder was created by philgsy
I'm not sure why and I'm hoping that someone can help me.
With our site, we've been working with our payment provider to create a plugin for HikaSHop which is now complete.
For some reason though, the return nnotifications from the provider are not working on the site.
I've tested this on a "clean" site and it seemed to work ok, which I cant explain...
$pluginsClass = hikashop_get('class.plugins');
$ppages = new HikashopPPages();
$elements = $pluginsClass->getMethods('payment','securetradingppages');
if(empty($elements) || !isset($elements[1])) {
$ppages->createException(new Exception('The payment module class could not be retrieved correctly.'), __FILE__, __CLASS__, __LINE__);
$filter = &JFilterInput::getInstance();
$paymentMethod = $elements[1];
$postVars = array();
foreach($_POST as $key => $value){
$key = $filter->clean($key);
$value = JRequest::getString($key);
$postVars[$key]=$value;
if (!isset($postVars['errorcode'])) {
$ppages->createException(new Exception('The errorcode has not been set.'), __FILE__, __CLASS__, __LINE__);
if (!isset($postVars['orderreference'])) {
$ppages->createException(new Exception('The orderreference has not been set.'), __FILE__, __CLASS__, __LINE__);
if ($paymentMethod->payment_params->usenotificationhash && !isset($postVars['responsesitesecurity'])) {
$ppages->createException(new Exception('The notification hash is enabled but the reponsesitesecurity was not posted to the notification script.'), __FILE__, __CLASS__, __LINE__);
if (isset($postVars['responsesitesecurity']) && $postVars['responsesitesecurity'] !== hash('sha256', $postVars['errorcode'] . $postVars['orderreference'] . $paymentMethod->payment_params->notificationhash)) {
$ppages->createException(new Exception('The notification hash is enabled but the responsesitesecurity field did not match the regenerated hash.'), __FILE__, __CLASS__, __LINE__);
$orderClass = hikashop_get('class.order');
$dbOrder = $orderClass->get($postVars['orderreference']);
if(empty($dbOrder)){
$ppages->createException(new Exception('Could not load order using orderreference: ' . $postVars['orderreference']), __FILE__, __CLASS__, __LINE__);
$order = NULL;
$order->order_id = $dbOrder->order_id;
$order->old_status->order_status=$dbOrder->order_status;
if ($postVars['errorcode'] == 0) {
$order->order_status = $paymentMethod->payment_params->verified_status;
else {
$order->order_status = $paymentMethod->payment_params->invalid_status;
$order->history->history_notified = 1;
$orderClass->save($order);
exit('Notification Complete.');
Last edit: 14 years 1 month ago by philgsy.
14 years 1 month ago #62006
by Jerome
Replied by Jerome on topic Re: Payment notification does not work with CBuilder
In which function does your code source came from ?
Does the notification url is right ?
Are you sure that the notification is called ?
What's "HikashopPPages" ? Does it right included and defined ?
Do you check your PHP log file ?
Time to create page: 0.129 seconds
