problem with bridge controller
12 years 2 weeks ago #75646
Hi! Today i am try Hika shop 2.0 Starter on Joomla 2.5.8
Fatal error: Cannot redeclare class hikashopBridgeController in /home/t/times/*********/public_html/administrator/components/com_hikashop/helpers/helper.php on line 918
Help me please
  • Thank you received: 13379
12 years 2 weeks ago #75661
On which page do you get that error ? What is the link ?
Could you turn on the "debug mode" and "error reporting" to maximum in the joomla configuration and give a screenshot of the page ?
12 years 2 weeks ago #75707
This error i can see in Hika shop default menus. I choice "categories listing" or "products listing" and system write:
options
Fatal error: Cannot redeclare class hikashopBridgeController in /home/t/times/timestravel.ru/public_html/administrator/components/com_hikashop/helpers/helper.php on line 918.
See (for example)attach file "view categories listing menu' or index.php
And on this page i can not see debug mode.
Next debug report from Hika shop default menus
32 SQL-запросов зафиксировано
SELECT `data`
FROM `travel_session`
WHERE `session_id` = 'e2e3e30d91c83a279437a343021a7df0'
DELETE
WHERE `time` < '1352651909'
SELECT extension_id AS id, element AS "option", params, enabled
FROM travel_extensions
WHERE `type` = 'component'
AND `element` = 'com_languages'
SELECT folder AS type, element AS name, params
WHERE enabled >= 1
AND type ='plugin'
AND state >= 0
AND access IN (1,1,2,3)
ORDER BY ordering
SELECT template
FROM travel_template_styles as s
WHERE s.client_id = 0
AND s.home = 1
SELECT template
AND s.home = 1
SELECT extension, file, type
FROM travel_rokcommon_configs
ORDER BY priority
SELECT template, s.params
LEFT JOIN travel_extensions as e
ON e.type='template'
AND e.element=s.template
AND e.client_id=s.client_id
WHERE s.client_id = 1
AND home = 1
ORDER BY home
AND `element` = 'com_k2'
SHOW FULL COLUMNS
FROM `travel_extensions`
SELECT `extension_id`
WHERE type = 'component'
AND element = 'com_roksprocket'
SELECT *
WHERE `extension_id` = '10049'
WHERE type = 'module'
AND element = 'mod_roksprocket'
SELECT *
AND `element` = 'com_rokcandy'
SELECT *
FROM travel_rokcandy
WHERE published=1
SELECT id, home, template, params
WHERE client_id = 0
AND `element` = 'com_menus'
SELECT a.id, a.menutype, a.title, a.alias, a.note, a.path, a.link, a.type, a.parent_id, a.level, a.published as apublished, a.component_id, a.ordering, a.checked_out, a.checked_out_time, a.browserNav, a.access, a.img, a.template_style_id, a.params, a.lft, a.rgt, a.home, a.language, a.client_id,
CASE a.type WHEN 'component' THEN a.published+2*(e.enabled-1) WHEN 'url' THEN a.published+2 WHEN 'alias' THEN a.published+4 WHEN 'separator' THEN a.published+6 END AS published,l.title AS language_title, l.image as image,u.name AS editor,c.element AS componentname,ag.title AS access_level,e.name AS name
FROM `travel_menu` AS a
LEFT JOIN `travel_languages` AS l
ON l.lang_code = a.language
LEFT JOIN `travel_users` AS u
ON u.id = a.checked_out
LEFT JOIN `travel_extensions` AS c
ON c.extension_id = a.component_id
LEFT JOIN travel_viewlevels AS ag
ON ag.id = a.access
LEFT JOIN travel_extensions AS e
ON e.extension_id = a.component_id
WHERE a.id > 1
AND a.client_id = 0
AND (a.published IN (0, 1))
AND a.menutype = 'hikashop_default'
ORDER BY a.lft asc
ON ag.id = a.access
WHERE a.id > 1
AND a.client_id = 0
ORDER BY a.lft asc
SELECT menutype AS value, title AS text
FROM `travel_menu_types`
ORDER BY title
SELECT a.id AS value, a.title AS text
FROM `travel_viewlevels` AS a
GROUP BY a.id, a.title, a.ordering
ORDER BY a.ordering ASC
SELECT a.lang_code AS value, a.title AS text, a.title_native
FROM travel_languages AS a
WHERE a.published >= 0
ORDER BY a.title
ORDER BY title
SELECT a.id AS value, a.title AS text, a.level, a.menutype
FROM travel_menu AS a
WHERE a.parent_id > 0
AND a.type <> 'url'
AND a.client_id = 0
AND a.published IN (0,1)
ORDER BY a.lft
SELECT m.id, m.title, m.module, m.position, m.content, m.showtitle, m.params, mm.menuid
FROM travel_modules AS m
LEFT JOIN travel_modules_menu AS mm
ON mm.moduleid = m.id
ON e.element = m.module
AND e.client_id = m.client_id
WHERE m.published = 1
AND e.enabled = 1
AND (m.publish_up = '0000-00-00 00:00:00' OR m.publish_up <= '2012-11-11 17:38:29')
AND (m.publish_down = '0000-00-00 00:00:00' OR m.publish_down >= '2012-11-11 17:38:29')
AND m.access IN (1,1,2,3)
AND m.client_id = 1
AND (mm.menuid = 0 OR mm.menuid <= 0)
ORDER BY m.position, m.ordering
SELECT COUNT(*)
FROM travel_messages
WHERE state = 0
AND user_id_to = 214
SELECT COUNT(session_id)
FROM travel_session
WHERE guest = 0
AND client_id = 1
FROM travel_session
WHERE guest = 0
AND client_id = 0
SELECT a.*, SUM(b.home) AS home,b.language,l.image,l.sef,l.title_native
FROM travel_menu_types AS a
LEFT JOIN travel_menu AS b
ON b.menutype = a.menutype
AND b.home != 0
LEFT JOIN travel_languages AS l
ON l.lang_code = language
WHERE (b.client_id = 0 OR b.client_id IS NULL)
GROUP BY a.id, a.menutype, a.description, a.title, b.menutype,b.language,l.image,l.sef,l.title_native
SELECT m.id, m.title, m.alias, m.link, m.parent_id, m.img, e.element
FROM travel_menu AS m
ON m.component_id = e.extension_id
WHERE m.client_id = 1
AND e.enabled = 1
AND m.id > 1
ORDER BY m.lft
UPDATE `travel_session`
SET `data` = '__default|a:9:{s:15:\"session.counter\";i:59;s:19:\"session.timer.start\";i:1352652427;s:18:\"session.timer.last\";i:1352655478;s:17:\"session.timer.now\";i:1352655509;s:24:\"session.client.forwarded\";s:14:\"46.180.119.200\";s:22:\"session.client.browser\";s:72:\"Mozilla/5.0 (Windows NT 6.1; WOW64; rv:16.0) Gecko/20100101 Firefox/16.0\";s:8:\"registry\";O:9:\"JRegistry\":1:{s:7:\"\0*\0data\";O:8:\"stdClass\":5:{s:11:\"application\";O:8:\"stdClass\":1:{s:4:\"lang\";s:0:\"\";}s:9:\"com_menus\";O:8:\"stdClass\":2:{s:4:\"edit\";O:8:\"stdClass\":1:{s:4:\"item\";O:8:\"stdClass\":4:{s:2:\"id\";a:1:{i:0;i:417;}s:4:\"data\";N;s:4:\"type\";N;s:4:\"link\";N;}}s:5:\"items\";O:8:\"stdClass\":2:{s:6:\"filter\";O:8:\"stdClass\":1:{s:8:\"menutype\";s:16:\"hikashop_default\";}s:10:\"limitstart\";i:0;}}s:13:\"com_installer\";O:8:\"stdClass\":2:{s:7:\"message\";s:0:\"\";s:17:\"extension_message\";s:0:\"\";}s:11:\"com_plugins\";O:8:\"stdClass\":1:{s:7:\"plugins\";O:8:\"stdClass\":4:{s:6:\"filter\";O:8:\"stdClass\":4:{s:6:\"search\";s:10:\"отлад\";s:6:\"access\";i:0;s:5:\"state\";s:0:\"\";s:6:\"folder\";s:0:\"\";}s:10:\"limitstart\";i:0;s:8:\"ordercol\";s:7:\"enabled\";s:9:\"orderdirn\";s:3:\"asc\";}}s:6:\"global\";O:8:\"stdClass\":1:{s:4:\"list\";O:8:\"stdClass\":1:{s:5:\"
limit\";i:0;}}}}s:4:\"user\";O:5:\"JUser\":26:{s:9:\"\0*\0isRoot\";b:1;s:2:\"id\";s:3:\"214\";s:4:\"name\";s:12:\"Виктор\";s:8:\"username\";s:6:\"admin2\";s:5:\"email\";s:22:\"v.gunin@timestravel.ru\";s:8:\"password\";s:65:\"c4a0e1887134fe92bb17078a19de9394:6jqaF17Fyy5E50siRhUdBwSNGdmK1btt\";s:14:\"password_clear\";s:0:\"\";s:8:\"usertype\";s:0:\"\";s:5:\"block\";s:1:\"0\";s:9:\"sendEmail\";s:1:\"1\";s:12:\"registerDate\";s:19:\"2012-07-16 10:41:11\";s:13:\"lastvisitDate\";s:19:\"2012-11-11 06:39:09\";s:10:\"activation\";s:0:\"\";s:6:\"params\";s:92:\"{\"admin_style\":\"\",\"admin_language\":\"\",\"language\":\"\",\"editor\":\"\",\"helpsite\":\"\",\"timezone\":\"\"}\";s:6:\"groups\";a:1:{i:8;s:1:\"8\";}s:5:\"guest\";i:0;s:13:\"lastResetTime\";s:19:\"0000-00-00 00:00:00\";s:10:\"resetCount\";s:1:\"0\";s:10:\"\0*\0_params\";O:9:\"JRegistry\":1:{s:7:\"\0*\0data\";O:8:\"stdClass\":6:{s:11:\"admin_style\";s:0:\"\";s:14:\"admin_language\";s:0:\"\";s:8:\"language\";s:0:\"\";s:6:\"editor\";s:0:\"\";s:8:\"helpsite\";s:0:\"\";s:8:\"timezone\";s:0:\"\";}}s:14:\"\0*\0_authGroups\";a:2:{i:0;i:1;i:1;i:8;}s:14:\"\0*\0_authLevels\";a:4:{i:0;i:1;i:1;i:1;i:2;i:2;i:3;i:3;}s:15:\"\0*\0_authActions\";N;s:12:\"\0*\0_errorMsg\";N;s:10:\"\0*\0_errors\";a:0:{}s:3:\"aid\";i:0;s:3:\"gid\";i:1000;}s:13:\"session.token\";s:32:\"74997b54b9d90480a997e84501fd9030\";}__wf|a:1:{s:13:\"session.token\";s:32:\"d71628cb7b4cdbbfddf4b07c1b5120c9\";}' , `time` = '1352655509'
23 типов SQL-запросов зафиксировано, отсортировано по вхождениям
Запросы типа SELECT:
4 × SELECT extension_id AS id, element AS "option", params, enabled
2 × SELECT *
2 × SELECT a.id, a.menutype, a.title, a.alias, a.note, a.path, a.link, a.type, a.parent_id, a.level, a.published as apublished, a.component_id, a.ordering, a.checked_out, a.checked_out_time, a.browserNav, a.access, a.img, a.template_style_id, a.params, a.lft, a.rgt, a.home, a.language, a.client_id,
ON ag.id = a.access
2 × SELECT menutype AS value, title AS text
2 × SELECT COUNT(session_id)
FROM travel_session
2 × SELECT `extension_id`
2 × SELECT template
1 × SELECT m.id, m.title, m.alias, m.link, m.parent_id, m.img, e.element
1 × SELECT a.id AS value, a.title AS text, a.level, a.menutype
1 × SELECT m.id, m.title, m.module, m.position, m.content, m.showtitle, m.params, mm.menuid
1 × SELECT a.*, SUM(b.home) AS home,b.language,l.image,l.sef,l.title_native
AND b.home != 0
1 × SELECT COUNT(*)
1 × SELECT a.lang_code AS value, a.title AS text, a.title_native
1 × SELECT id, home, template, params
1 × SELECT extension, file, type
1 × SELECT folder AS type, element AS name, params
1 × SELECT template, s.params
1 × SELECT *
1 × SELECT `data`
Прочие SQL-запросы:
1 × UPDATE `travel_session`
1 × SHOW FULL COLUMNS
1 × DELETE
12 years 2 weeks ago #75716
Could you add the code below at the beginning of the file administrator/components/com_hikashop/helpers/helper.php ?
<?php
if(class_exists('hikashopBridgeController')){
$reflector = new ReflectionClass('hikashopBridgeController');
echo 'Already defined in file ' $reflector->getFileName();
echo ' on line '.$reflector->getStartLine();
exit;
That will tell us where the class hikashopBridgeController is defined before joomla calls HikaShop. Normally, that class should be unique to HikaShop.
12 years 2 weeks ago #75789
OK. But you can do differently? I can make a mistake when replacing. Can you put here the file with these changes. and I will change my file to your.
12 years 2 weeks ago #75790
There is nothing to replace. You just need to copy/paste that text at the top of the file, before anything.
If you're able to write in a forum, you should be able to copy/paste some text in a file :)
12 years 2 weeks ago #75798
OK :) It is right i hope?
<?php
exit;
<?php
* @version 2.0.0
* @author hikashop.com
?><?php
jimport('joomla.application.component.controller');
jimport('joomla.application.component.view');
but after this change a System write next information
options
Parse error: syntax error, unexpected T_VARIABLE, expecting ',' or ';' in /home/t/times/timestravel.ru/public_html/administrator/components/com_hikashop/helpers/helper.php on line 4
12 years 2 weeks ago #75929
Yes, that's right.
I've made a mistake in the code though. It should be:
<?php
echo 'Already defined in file '.$reflector->getFileName();
exit;
Please try with that code instead.
12 years 2 weeks ago #75954
Ok i do it.
HikaShop Options
options Already defined in file /home/t/times/timestravel.ru/public_html/administrator/components/com_hikashop/helpers/helper.php on line 928
for example lines 928: class hikashopBridgeController extends JControllerLegacy {}
What can i do else?
12 years 2 weeks ago #76106
Ok. Then, remove the code that you added at the top and change the line:
by:
if(!class_exists('hikashopBridgeController')){ class hikashopBridgeController extends JControllerLegacy {} }
in that same file. That will solve that error.
12 years 2 weeks ago #76171
OK.
options
Fatal error: Cannot redeclare class hikashopBridgeView in /home/t/times/public_html/administrator/components/com_hikashop/helpers/helper.php on line 1326
1326 class hikashopBridgeView extends JView {}
  • Thank you received: 4028
12 years 2 weeks ago #76220
It is the same kind of error.
Please replace the line
By
if(!class_exists('hikashopBridgeView ')){ class hikashopBridgeView extends JView {} }
