Problem with link from mini cart to checkout
11 years 10 months ago #85652
The link between my mini cart and the checkout page does not appear to be working, I get the message this page cannot be displayed.
www.kitesyd.dk/new/index.php/da/
11 years 10 months ago #85667
The url seems to be correct. But I have a timeout, the pages take so much time to load.
11 years 10 months ago #86500
Hi again,
I have been playing around with this but i don't seem to be able to get the page to load quicker, have you any suggestions as to how I can improve this?
thanks
Matt
  • Thank you received: 13379
11 years 10 months ago #86575
I honestly has no idea on why you would get that on the checkout page.
Did you change something in the checkout options ?
Could you do a screenshot of the checkout options of the configuration ?
Also, it would be great if you could get the error message in the logs of your hosting (you might need to ask your hosting provider for it).
11 years 10 months ago #87300
Sorry for my slow response, I have been a little busy. Here is the print screen you asked for.
regards,
matt
11 years 10 months ago #87301
regards,
matt
11 years 9 months ago #87689
The settings there are fine.
We would really need you to get the error message in the logs of your hosting in order to understand why it's not displaying that page.
11 years 9 months ago #88585
my webhost does not provide php error logs, but they have instructed me to take the error messages from my web pages.
Warning: array_merge(): Argument #2 is not an array in /customers/7/0/1/kitesyd.dk/httpd.www/plugins/content/jsshareit/jsshareit.php on line 258 Warning: array_unique() expects parameter 1 to be array, null given in /customers/7/0/1/kitesyd.dk/httpd.www/plugins/content/jsshareit/jsshareit.php on line 262 Warning: Invalid argument supplied for foreach() in /customers/7/0/1/kitesyd.dk/httpd.www/plugins/content/jsshareit/jsshareit.php on line 334
This is the only one I could find as the page in question will not load. I hope thiat this helps?
cheers
Matt
11 years 9 months ago #88788
These errors are not HikaShop related, try to see with the provider of this plugin how to correct these errors.
11 years 9 months ago #88822
Ok thanks for the info ;)
I have altered the settings in the back end and changed the module to a mini cart, I am now able to load the page, does this information help you with sorting the problem?
cheers
Matt
11 years 9 months ago #88922
Had you edited the view "product / cart" ?
I'm still not able to load the checkout page by clicking on the link in the mini cart.
Are you using a sef component ?
11 years 9 months ago #90219
Hi again,
The only edit I have made to the mini cart, was a small entry in the css file to change the font colour on the price, I do not know what a sef component is.
If have ran a validation check and that throws up several errors, here is the link
validator.w3.org/check?uri=kitesyd.dk&ch...ctype=Inline&group=0
Sorry I am not a developer so I am a bit of a novice when it comes down to it. :blush:
cheers
Matt
11 years 9 months ago #90393
So it's working now ?
I don't understand what was changed since you were apparently already using the mini cart but if it's working now then it's all good.
Unfortunately, none of the error messages your provided are related to the error page that you had. So that doesn't help us. We would really need the error message from the PHP error log of your server.
