Interaction between related products and cart
  • Thank you received: 5
13 years 5 months ago #19263
Have a screen showing a product and below it a list of related products.
On the right hand side is a cart module.
The product always displays correctly.
When the cart is either empty or the module disabled the related products display correctly.
Related product prices show as:
£6.78 each ADD TO CART
When the cart is populated related products do not display correctly.
£6.78 ADD TO CART
The each is missing.
In the template file list_price.php there is a check:
if(isset($price->price_min_quantity) && empty($this->cart_product_price)){
if($price->price_min_quantity>1){
This works correctly for the cart but for related products it looks like the value of $this->cart_product_price has leaked across as it is set when processing related products.
13 years 5 months ago #19264
A quick fix is to put the following line at the end of the product cart.php view file.
unset($this->cart_product_price);
  • Thank you received: 13372
13 years 5 months ago #19289
Thanks. We'll change that for next release.
