Shopping cart problems on front page
12 years 6 months ago #48964
Im sure there's probably a simple answer to this but after 2 hours of trying different options to fix this I have ran out of ideas.
My shopping cart works fine on all pages apart from my home page, the home page is set up as a category listing. When i click proceed to checkout it just leaves me on the front page and adds /index.php/checkout at the end of the address.
Also product links in the cart dont work,you click on them and the page title changes, but I remain on the front page.
Any ideas would be much appreciated, thanks
  • Thank you received: 13372
12 years 6 months ago #49040
Could you provide a link to your shop so that we can see the problem ?
12 years 6 months ago #49090
12 years 6 months ago #49187
It seems related to the SEF on your website.
Are you using a specific SEF component ?
What if you turn off SEF in the joomla configuration/SEF component ? Does it work ?
It might be related to your template too. What if you keep SEF on and switch your template ?
