Products to display side by side
11 years 5 months ago #106870
Hello, I tried everything to get my products to show side by side.
In all menus and modules I have.
Type of content Product
Type of layout Div
Columns 3
Items 20.
It seems like the parameters are too wide, but I see no adjustment for that.
Last edit: 11 years 5 months ago by zoo. Reason: typo
11 years 5 months ago #106874
This is probably caused by :
1. the fact that you are editing the wrong product listing menu/module
2. some CSS code.
Giving me a link to your page will probably help me to understand what the problem really is.
11 years 5 months ago #106876
www.pcwhiz.ca/index.php/services
Also my payments have no buttons beside them.
Glenn
11 years 5 months ago #106885
Ok, can you use the "Number of columns" option of your content menu which have the ID number 594 ?
11 years 5 months ago #106889
It's already set to 3 columns 20 items
  • Thank you received: 403
11 years 5 months ago #106895
Please post a screenshot of the module configuration page with the ID 594
11 years 5 months ago #106897
Here ya go.
11 years 5 months ago #106900
You're not editing the right module.
This one has layout type 'div' and the page you gave us has layout 'list'.
Find the right module before applying changes :)
11 years 5 months ago #106916
Hmmm, If I change the module from Div to List it looks like this.
11 years 5 months ago #106925
I don't understand what is going on becuase I was able to do this on two other sites I have created.
I've deleted modules, menus,recreated new menus modules, compared the side where I was able to put products in a row. I started new products. The best I can get it to diplay is Table view, oh well.
  • Thank you received: 13378
11 years 5 months ago #106978
The problem comes from your template actually. It doesn't support the bootstrap library. And you have the option "use bootstrap design" turned on in the configuration of HikaShop. But since your template doesn't support it, it screws the display like that.
Turn that option off and you won't have the problem anymore.
The following user(s) said Thank You: zoo
11 years 5 months ago #106995
Yes, that fixed it thanks Nicolas
