Problem with prices with iDeal extension
11 years 4 months ago #115408
I have installed hikashop and I am very pleased with it B)
Now I live in the Netherlands and here we have iDeal for payment. So I installed CC Ideal platform from Chill Creations.
Everything works but if I want to complete the order it says that "The total amount is not a valid number" in Dutch: Bedrag moet een geldig nummer zijn.
I googled this and it should be a problem with the prices of the products, due to the amount of decimals the system of Ideal does not understand it anymore.
If I put the amount including vat in two decimals, it sometimes works only then hikashop changes it to more decimals again.
A permanent solution would be appreciated :)
I cannot seem to find a solution for this. :unsure:
Anyone any ideas?
11 years 4 months ago #115431
Hi Suzeen
David from Chill Creations here. Did you also create a ticket on our website? We would like to have a look!
Kind regards
David
iDEAL for Hikashop by Dutch iDEAL experts
  • Thank you received: 13377
11 years 4 months ago #115435
Probably the rounding missing in the payment plugin. Chill Creations should indeed be able to help you on that.
11 years 4 months ago #115665
Problem solved by changing one line of code. Looks like the change we did a few months ago was reverted by mistake. Working again now.
11 years 4 months ago #115667
Problem is solved by Chill Creations
