Problem changing button style, arghh
13 years 11 months ago #4543
i'm trying to change the style of a button but it's making me crazy cause it won't work.
it's the button on the Address page ( the New Address button )
As you can see, the bottom button is perfect, as for the top button. it's not. ( only the background?¿? )
I tried searching every CSS file but i just cant find it :(
Cant somebody help me out here? thanks.
  • Thank you received: 13398
13 years 11 months ago #4546
Could you give the URL of your website ?
13 years 11 months ago #4547
Well it's offline since nobody may enter it atm. why you need it ? if you need some info you can ask it. i did try the 'inspect element' feature in chrome but that did not help either.
13 years 11 months ago #4549
Using firebug addon for firefox, you can inspect and tweak CSS on the fly which is really helpful to understand/fix/test all CSS issues.
Anyway, that button isn't made like the other one so that's why by default it may have a different look. YOu can just edit the file components/com_hikashop/views/checkout/tmpl/address_view.php and replace the line:
<input type="button" name="new" value="<?php echo JText::_('NEW');?>"></input>
by:
echo $this->cart->displayButton(JText::_('NEW'),'new',$this->params,'','return false;');
surrounded by the PHP open and close tags: <?php and ?>
Last edit: 13 years 11 months ago by nicolas.
13 years 11 months ago #4555
by:
You just made my day. I love you <3 :side: :woohoo:
