How to change "$0.10 per unit for buying at least 100"
  • Thank you received: 13502
4 years 10 months ago #318636
What are you trying to do ?
To have different rates for different categories of products ?
That's possible. In each user points plugin instance, you can enter the rate, and select the categories you want in the "Product categories" setting so that only the products in these categories will give points.
4 years 10 months ago #318676
No.. I am trying to make a few points packages such as "100 points" for $ 10 and "534 points" for $ 20
those. it turns out that each product has a different number of points for 1 dollar
Before that you told me -
"There, you'll find a "rate" setting which allows you to give a certain number of points for each euro spent and you can restrict this to a category of products."
And here is my actual question -
Can I bind a plugin to a product, not a category?
Last edit: 4 years 10 months ago by fr1g0s.
4 years 10 months ago #318689
Well, yes and no.
You can't directly bind a user points plugin instance to a product, but you can bind it to an unpublished category and add that unpublished category as second category to your product so that the user points plugin instance will only be valid for that product.
Time to create page: 0.039 seconds
