Problem with UPS plugin
13 years 8 months ago #22527
Joomla 1.7.0
Hikashop: 1.5.3
Problem: In UPS plugin configuration the warehouse settings are not being saved.
So per the documentation I need to set up a warehouse. I give it a name, zip code, and country (units and currency already filled in). I click on save and this information disappears.
I try again this time give it a name, zip code, country, click ADD, then save. It disappears.
I Click add, give it a name, zip code, country, then save, disappears.
  • Thank you received: 13533
13 years 8 months ago #22532
Thank you for the report. That happens when you don't set a zone for a warehouse. We've put together a new version which fixes that behavior. If you download again HikaShop and update, that should solve the problem.
Time to create page: 0.032 seconds
