problem with add product
12 years 3 months ago #86657
Hello everyone,
I have hikashop almost one year, and everything is okey, but now i have problem when i want to add new product.
I open editor and set name, description, price. When i click on add button for category, images and related product does not open windows.
Please help.
Best Regards,
Elektronika-projekti.com
Last edit: 12 years 3 months ago by marko05nikolic.
12 years 3 months ago #86694
I didn't really understood what your problem is, so can you explain it again through some screenshots ?
Thanks ?
Last edit: 12 years 3 months ago by Mohamed Thelji.
12 years 3 months ago #86722
when i click to add categories, does not open a window where you can choose a category, also with related products and images.
i okey now?
12 years 3 months ago #86758
Ok so, can you :
1. Turn on the debug mode and the error reporting options of the joomla configuration and try it again. Then tell me if it display some error message ?
2. See if you have a JavaScript error ?
12 years 3 months ago #86824
Javascrip do not have error.
I turn on system debug in global configuration and dont see anything error messages. Do you mean on that error reporting options of the joomla configuration ?
12 years 3 months ago #86845
Same problem with change status of orders. also i cant send email to customer is order confirm, shipp or something else.
12 years 3 months ago #86905
If the Add button doesn't work anywhere, it's maybe caused by a plugin using jquery on your backend and that breaks the mootools javascript library which handle the popups.
I would recommend that you try to disable the system plugins one by one to see which one is causing that problem.
The extension jquery easy can most of the times fix these kind of issues so you could also try to use it.
The following user(s) said Thank You: marko05nikolic
12 years 3 months ago #86919
Problem was with system plugin HikaShop Product Insert and System - Best Alias, when I diseble everything was okey. I am interesting may leave them diseble?
12 years 3 months ago #86923
If you are not using them sure you can let them disabled, but that's weird, the Hikashop product insert plugin isn't using Jquery :).
12 years 3 months ago #86926
i turn on Hikashop product insert plugin and adding work but best alias make some problem. hi is diseble now and everthing is okey.
thanks a lot.
loading
