problem with product export
13 years 3 months ago #35803
hello,
I'm trying to export my products to excel, however they don't seem to be seperated properly. for example some of the product descriptions can be found in the product id collumn when i view them in excel. this is happening with other collums too. i've set the seperator to comma (in the configuration menu), and i've set the excel file import seperator to comma too when i import the file. is there something i'm missing...? any help would be much appreciated
Tanya
  • Thank you received: 13533
13 years 3 months ago #35807
Could you switch to semi colon for both HikaShop and Excel and try again ?
13 years 3 months ago #35872
ok thanks for getting back to me - i've tried that but it still won't work. i've attached a pic of what the text import wizard looks like on my end. I've also tried it on my home computer (newer version of excel on it) but it still mixes up the data.
13 years 3 months ago #35875
Could you give the CSV so that we can check it ?
13 years 3 months ago #35878
hi,
yes i can give you the csv - just warning you though that its very large so you can't just click on it to open it. i had to import it manually using the data import options in excel (fits over more than one worksheet). its still set at semi colon for the separator.
Tanya
13 years 3 months ago #35879
hi,
Tanya
Last edit: 13 years 3 months ago by tanyatanya.
13 years 3 months ago #35881
sorry i can't get it to attach - maybe its too large...the page just keeps loading and as you can see it didn't attach to the message. can i send it to you in an email?
13 years 3 months ago #35940
Sure. You can send it to nicolas at hikashop dot com.
13 years 3 months ago #36063
I've opened your CSV on my end with open office calc ( I don't have excel. That's a free equivalent to excel ) and it's displaying fine. So It must be excel not interpreting properly the CSV.
I see that you ticked tab as a delimiter when opening the CSV. You might want to try again with that option unticked. That might help Excel.
13 years 2 months ago #36356
ok I'll try that, if that doesn't work I'll try using the open office calc (I have that on my computer too).
thanks,
Tanya
13 years 2 weeks ago #45580
I am also having problems with the export function.
I am using semicolon as the CSV separator but can see on a single product export test that the field order in the file is disturbed when I read it back into Excel.
The problem appears to be connected to the product description field, where I think that a character or string in the product description is causing a a new line to be started.
In the attached file, if I do the following:
1. Import the csv file into Excel
2. Take all the data on the line after the field "xxTest_Product_Top" (which is the text product code)
3. Move that data so that it starts in the correct field (product_code)
then the remaining data items will then be placed in the correct fields.
I have attached the data file so that you can see the problem.
My original objective was simply to check product names, codes, prices, tax status etc. I do not need the product description in order to do this. Is there any way to select which data items I want to appear in the exported CSV file (without using a SQL query?) so that I do not export the product description?
PhilP
13 years 2 weeks ago #45812
Having several lines in a CSV field is not a problem.
Could you try to open your CSV with libreoffice (openoffice) calc ? It should work better than with Excel.
Excel has sometimes troubles to open CSV files properly...
There is no option to only export some fields.
13 years 2 weeks ago #45849
Ok Nicolas - thanks. I'll try that.
PhilP
