Problem Saving New Products and/or editing old!
12 years 2 weeks ago #97281
Hi I can't edit or save new products! It just says: "Error - Save failed" (or in Swedish: "Fel - spara misslyckades")
It's a new website and the first products were imported by CSV-file. Have anyone had this problem before?
  • Thank you received: 13536
12 years 2 weeks ago #97313
Turn on the debug mode of the joomla configuration and that should display an error message with more information on the issue.
12 years 2 weeks ago #97325
This is the error message I got!
Joomla!
500 - Ett fel har inträffat
JDatabaseMySQLi::query: 1054 - Unknown column 'product_canonical' in 'field list' SQL=INSERT IGNORE INTO `jos_allergeko_se_hikashop_product` ( `product_name`,`product_url`,`product_meta_description`,`product_keywords`,`product_page_title`,`product_alias`,`product_code`,`product_tax_id`,`product_manufacturer_id`,`product_layout`,`product_quantity`,`product_min_per_order`,`product_max_per_order`,`product_sale_start`,`product_sale_end`,`product_canonical`,`product_msrp`,`product_weight`,`product_weight_unit`,`product_length`,`product_width`,`product_dimension_unit`,`product_height`,`product_published`,`product_type`,`product_description`,`product_modified`,`product_created` ) VALUES ( 'Veggie Spread Basilika','','','','','','Veggie_Spread_Basilika','11','0','','-1','0','0','','','','','','kg','','','m','','1','main','
Glutenfri, mjölkfri, sojafri pålägg med Basilika 180g eller 50g
\r\n
Veggie Spread
\r\n
Ingredienser: Solrosfrö 39%, solrosolja*, vatten, citronsaft*, basilika*(7%), lök, havsalt
\r\n
*= ekologisk ingrediens
','1364894859','1364894859' )
Tillbaka till kontrollpanel
Call stack
# Function Location
1 JAdministrator->dispatch() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/administrator/index.php:46
2 JComponentHelper::renderComponent() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/administrator/includes/application.php:153
3 JComponentHelper::executeComponent() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/libraries/joomla/application/component/helper.php:351
4 require_once() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/libraries/joomla/application/component/helper.php:383
5 hikashopController->execute() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/administrator/components/com_hikashop/hikashop.php:54
6 JController->execute() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/administrator/components/com_hikashop/helpers/helper.php:1217
7 hikashopController->apply() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/libraries/joomla/application/component/controller.php:761
8 hikashopController->store() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/administrator/components/com_hikashop/helpers/helper.php:1003
9 hikashopProductClass->saveForm() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/administrator/components/com_hikashop/helpers/helper.php:1067
10 hikashopProductClass->save() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/administrator/components/com_hikashop/classes/product.php:204
11 hikashopClass->save() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/administrator/components/com_hikashop/classes/product.php:463
12 JDatabase->query() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/administrator/components/com_hikashop/helpers/helper.php:1268
13 JDatabaseMySQLi->execute() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/libraries/joomla/database/database.php:1253
14 JError::raiseError() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/libraries/joomla/database/database/mysqli.php:396
15 JError::raise() /www/webvol18/ww/ptsfxurssnviz7y/allergeko.se/public_html/libraries/joomla/error/error.php:251
12 years 2 weeks ago #97361
It means that there was an issue with the update of the database structure and you didn't get the new column "product_canonical" in the product table.
Download again HikaShop on our website, install it again and that should force the column to be added to the table and you won't have the error anymore.
12 years 2 weeks ago #97444
It didnt work Im afraid! Do I need to uninstall it completely to make it work? Could it be that its something caused by the CSV-file that was imported? So if I reinstall it and run the CSV-file again i'll get the same problem again!?
12 years 2 weeks ago #97468
It's not a problem with the CSV.
If you remove the hikashop tables from the database and install the latest version, you should not get that error.
