Problem with comment
  • Thank you received: 4
12 years 2 months ago #62438
Hello
i installed the last release of hika 1.5.9
Today I found a problem with the comments and votes.
I selected the option to connect vote and comment.
I inserted a new comment, then i can see the stars but not the comment
this is strange, until last week it was fine.
is it a problem of the new version or something else?
Thanks and regards.
12 years 2 months ago #62545
Hi Teto,
I just tried the comments on my end with the last version of HikaShop, it's working fine.
You edited the view to display the products, don't you have mess a part of the content present in the page ?
In the show_tabular view of hikashop, the published comments are displayed in another tab, do you copy/paste this part in your tab view "Le vostre opinioni" ?
12 years 2 months ago #62565
Hello Xavier
to move the comments in another tab i used the Tabber v2.1.3 plug-in and i modified the view "product / Show default" and "product / show".
To do that i followed the instruncton of this post www.hikashop.com/en/forum/4-how-to/56993...on-product-page.html
Until last week everything was fine.
I didn't modify the view show_tabular
I didn't change nothing, on monday I installed the new versione 1.5.9 and yesterday i verified I cannot see the comments.
Do you have any ideas?
12 years 2 months ago #62593
For the moment I just think that a part of code is missing.
Can you chekc if you have these lines:
	<div id="hikashop_product_vote_listing" class="hikashop_product_vote_listing">
		<?php
		if($this->params->get('show_vote_product')){
			$js = '';
			if(isset($this->element->main)){
				$product_id = $this->element->main->product_id;
			}else{
				$product_id = $this->element->product_id;
			$this->params->set('product_id',$product_id);
			echo hikashop_getLayout('vote', 'listing', $this->params, $js);
	</div>
In you show_default view.
12 years 2 months ago #62605
Hello
i had this code
[code type=php-brief]
<?php
$js = '';
$params = null; //Params already existing in the previous getLayout('vote', ...)
echo hikashop_getLayout('vote', 'listing', $params, $js);
</div>
[/code]
Did you modify this view from 1.5.8 to 1.5.9?
I didn't touch this part.
Anyway I substituted the existing code with the one you indicated me and now it works
Thank you very much!
Last edit: 12 years 2 months ago by Teto.
12 years 2 months ago #62608
I think that it has been changed between these two versions, can you try to change your code by my code please.
12 years 2 months ago #62612
I did it, it works.
Thank you!!! :cheer:
