Best way to Selectively No Index Some Products
9 years 5 months ago #215972
Yup, that is actually the way I have it.
  • Thank you received: 4032
9 years 5 months ago #215975
Can you please try with that code ?
if(isset($this->element))
  $noindex = strtolower(trim($this->element->meta_noindex));
else
  $noindex = strtolower(trim(@$this->row->meta_noindex));
if($noindex == 'true') {
So we will avoid any kind of problem between "show" and "listing" views :)
8 years 7 months ago #247199
Does it work?
  • Thank you received: 6
2 years 7 months ago #343619
Hi nicolas
It seems that this solution cannot be implemented in version 4.6.1. I can't find the link to add the no-index rel to it.
  • Thank you received: 652
2 years 7 months ago #343633
Sorry for this return but can you precise your idea, where didn't you find the "$link", in which view please.
We have to check is the url link and therefore the modification should always be possible, or else we are not talking about the same thing, hence my request for clarification.
Last edit: 2 years 7 months ago by Philip.
The following user(s) said Thank You: levelup
2 years 7 months ago #343701
Hi Philip
In Hikashop version 4.4.4 in the listing_img_title layout,, I created a custom field of the product type called indexnoindex, which will add the rel="nofollow to the end of the product link when it is set to yes on the product management page.
<?php
 *------ Add this and add 'rel="nofollow"' at the end of product link in line 40 and 80
$index_noindex = '';
if($this->row->indexnoindex == '0' || $this->row->indexnoindex == '' ){
}else{
	$index_noindex = 'rel="nofollow"';
<?php if($haveLink) { ?>
			<a href="<?php echo $link;?>" title="<?php echo $this->escape($this->row->product_name); ?>" <?php echo $index_noindex;?> >
<?php } ?>
I can't find the product link in version 4.6.1
Last edit: 2 years 7 months ago by levelup.
2 years 7 months ago #343706
The product link is at the very beginning of the view code, and I think I get something about your current code, the $havelink variable is no longer written as is, now it's $this->havelink, see my screenshot to understand my point :
Hope this will help you to achieve your needs.
