Problem with recaptcha plugin. Help me!!!
12 years 3 months ago #85421
I have a problem with recaptcha plugin in my joomla 1.5.22 site. I install e activated the plugin but when I go on register form it appears this fatal error:
Fatal error: Call to undefined function hikashop_isSSL() in /xxx/xxx/xxxxxxx/plugins/system/recaptcha.php on line 96
Any solution?
HELP ME!!!
PLEASE
p.s.
I have some custom field activated in the registration form.
Last edit: 12 years 3 months ago by gidantrip.
12 years 3 months ago #85449
Can you check in your plugin if the line:
if(!include_once(rtrim(JPATH_ADMINISTRATOR,DS).DS.'components'.DS.'com_hikashop'.DS.'helpers'.DS.'helper.php')) return true;
is present before the line 96 ?
12 years 3 months ago #85460
Yes it is present in line 81 exactly!
It seems that the problem is with the custom field of hikashop because when I disable them it works...
12 years 3 months ago #85510
I solved the problem!!!!!
I change the code:
recaptcha_get_html($this->params->get('public_key'),null,hikashop_isSSL())
with:
recaptcha_get_html($this->params->get('public_key'))
in the file plugins/system/recaptcha.php
