Some Products WILL NOT Load Into Cart
  • Thank you received: 6
9 years 3 months ago #221529
-- Joomla version -- : 3.4.5
This has been my oldest and most stable HikaShop client.
The day of my holiday starting and now only some of the products will load into the cart, many simply wont load into the cart when added.
Canonical URLs are turned off and are not present. SH404SEF is off
I reloaded HikaShop. No change .
I am in Asia and dont have access to a proper computer .
I need to PM the Admin details.
Thank you.
  • Thank you received: 13480
9 years 3 months ago #221539
I'm actually not able to access your website:
take.ms/q6a0T
Did something happen ? Could you make sure that it is accessible ?
9 years 2 months ago #222402
I am back.
The website is completely accessible. Perhaps you had hit a down moment.
www.resumesthatwork.com.au
9 years 2 months ago #222536
When I try to access the website, it says this:
take.ms/uDFxE
There is apparently a javascript trojan on the website and my antivirus software blocks the display of the page to prevent any problem. Are you aware of that ?
I've tried on another computer and apparently it redirects to some scam web page.
9 years 2 months ago #222570
Found the script.
This cleared up the cart issues too.
I locked down the site some more.
Can you please check from your system if you are still getting that trojan warning on this site?
9 years 2 months ago #222622
No it is ok, we can reach your website correctly.
