Product translation problem
  • Thank you received: 15
1 year 2 months ago #349780
-- HikaShop version -- : 4.7.1
-- Joomla version -- : 4.2.8
-- PHP version -- : 8.1
The site previously had FaLang installed.
After migrating to 4.x, I removed the old FaLang and installed the new one. FaLang was only used to translate product names, and now Hika has it built in. I disabled the FaLang, but the translation of products does not work. It shows the translation in the product list, but it doesn't work in the product details. I turned the FaLang back on - it didn't work either.
Help
Tomek
  • Thank you received: 13099
1 year 2 months ago #349784
If you still have the falang_content table in the database, you will still see the translations from there in your backend, even with Falang disabled.
However, if the Falang driver plugin is disabled, the translations won't be used on the frontend.
If you want to switch to the built in translation system, you need to rename the falang_content table in the database. That way, you'll loose the translations in your backend, and you'll be able to add them back with the built in translation system and they will then appear on your frontend.
1 year 2 months ago #349852
Thanks Nicolas,
I understand the relationship between Falanga and Hika's translation.
Tomek
Last edit: 1 year 2 months ago by StudioPrzyLesie.
