Send 1 serial per product ordered not by quantity
  • Thank you received: 8
6 years 7 months ago #278695
Hello
We have been asked by a client if they can sell a product, which will have x number of licenses depending on the number chosen. However, when a user makes an order through Hikashop they only want to send 1 activation code per product ordered and then licenses will be distributed by a 3rd party application. They also want to have breakpoints for prices depending on the quantity being purchased.
Our main question is: Is there a way to only send 1 serial key per product no matter what the quantity is?
Example
Price breakpoints
1-4: $10
5-20: $8
21-40: $6
41-80: $3
I go to the online store and order the following:
Product A
Quantity: 75
Price: 75x3 = $225
Serials to send: 1
Product B
Quantity: 1
Price: $10
Serials to send: 1
Product C
Quantity: 10
Price: $80
Serials to send: 1
I have ordered 3 products, so I only should receive 3 serial keys - not 86 keys. Is this possible?
  • Thank you received: 4006
6 years 7 months ago #278708
You should not use the default feature of HikaSerial but use a plugin like "serial per order".
But that plugin will send X serial per order, not per different product in the cart.
Afterwards, you can use that plugin has a base and create your own custom plugin for your specific requirement.
6 years 7 months ago #278828
Hi Jerome,
Thanks for the quick reply. Just to clarify, once the plugin has been published and assigned to a serial pack we need to remove the serial pack assignment within hikashop for each product correct?
Cheers,
6 years 7 months ago #278855
If you do not want HikaSerial to generate serials for the products (depending the quantity) ; yes, you have to remove the pack assignation.
The following user(s) said Thank You: twhcreations
