I can not add serials to products in front end?
10 years 8 months ago #166477
-- HikaSerial version -- : 1.8.3
-- Joomla version -- : 3.3.3
-- PHP version -- : 5.5.14-1
I can not add serials to products in front end? no matter what I do in ACL
I see it, When I click on the cross(add) nothing happens the link is #
  • Thank you received: 4035
10 years 8 months ago #166479
The integration between HikaMarket and HikaSerial is for the moment still "simple".
You can create HikaSerial packs in the front-end but you can associate an existing HikaSerial pack (so, created in the backend) to a product in the front-end.
By activating the ACL (product / edit / plugins / hikaserial) you allow HIkaSerial to display his content like it display his content in the backend product edition.
The cross button should open a popup to select an HikaSerial pack but it looks like there is a javascript problem with Joomla 3.3
The best is to edit the view "front-end | your front-end template | productserial | market_block" (or directly the file "components/com_hikaserial/views/productserial/tmpl/market_block.php") and replace
if(!defined('HIKAMARKET_COMPONENT'))
	return;
By
	return;
$doc = JFactory::getDocument();
$doc->addScript(HIKASERIAL_JS.'hikaserial.js');
in the beginning of the view.
It will force the inclusion of the HikaSerial javascript and will open correctly the modal box in the product page.
We will update the HikaSerial package as soon as possible.
10 years 8 months ago #166488
I did edit "components/com_hikaserial/views/productserial/tmpl/market_block.php") and replace code
but When I click on the cross(add) nothing happens the link is #
10 years 8 months ago #166491
So I think the modal is right open but your template is not compatible with the bootstrap modals (so the modal is not visible in the page, due to some bootstrap missing CSS)
Please change the option "popup mode" to "mootools" in your HikaShop configuration (System > Configuration > Display > General display options).
www.hikashop.com/support/support/documen...html#display_general
10 years 8 months ago #166503
it works now :)
and i did edit market_block.php to orginal and it work to
thanks
10 years 8 months ago #166505
I can add but not save or apply it will not stick to the product
10 years 8 months ago #166507
I've update your HikaSerial with the latest build.
The saving problem is now fixed.
Sorry for the inconvenient.
10 years 8 months ago #166508
awesome :)
thanks for quick reply
