Problem with plugin: Group filter consumer
9 years 11 months ago #187825
-- HikaSerial version -- : 1.9.0
-- Joomla version -- : 3.3.6
Hi!
The choices under GROUPS are grey, and cannot be selected.
I have selected "Pack", named the new plugin and saved the new plugin.
What am I doing wrong?
  • Thank you received: 4030
9 years 11 months ago #187840
The checkboxes can be checked ; I just try in our demo website and there is no problem.
9 years 11 months ago #187846
I can make selections. But when I press save, the selections dissapear.
9 years 11 months ago #187847
I tried it on your testpage, and the same happened there.
demo.hikashop.com/administrator/index.ph...aserial&ctrl=plugins
9 years 11 months ago #187848
Thanks, I see now !
Please edit the file "administrator/components/com_hikaserial/views/plugin/view.html.php" and replace
	$aclType = hikaserial::get('type.acl');
	$html .= $aclType->display($key, @$this->element->$paramsType->$key, $type.']['.$paramsType);
By
	$html .= $aclType->display('data['.$type.']['.$paramsType.']['.$key.']', @$this->element->$paramsType->$key);
It will fix the issue and this patch will be include in the next HikaSerial release.
Thanks for the report.
The following user(s) said Thank You: kaimor
9 years 11 months ago #187859
