HikaSerial - How to assign specific products to a serial
3 years 6 months ago #335986
-- url of the page with the problem -- : www.willowcrossley.com/
-- HikaSerial version -- : 4.0.0
-- Joomla version -- : 3.10
-- PHP version -- : 7.4.18
Hi, I would like to restrict a voucher that people can buy to only be used for specific products or product category. Is this possible and if yes, where do I go to do this?
  • Thank you received: 4035
3 years 6 months ago #335989
The coupon generator is using a "coupon" as template :
www.hikashop.com/support/documentation/1...ugins-coupongen.html
You have to configure that coupon in HikaShop :
www.hikashop.com/support/documentation/1...p-discount-form.html
There you will find the restrictions.
Time to create page: 0.038 seconds
