Shopping cart product listing issue
14 years 2 months ago #16034
If I click the "Add to Cart" button and change the quantity to "0" on the cart page,
the page then says "The cart is empty".
But below these words, it displays the last 2 items that had been added to the cart
and it shows them twice.
When the cart is empty, I do not want to show any products on this page.
Where is the setting to fix this so that no products appear?
  • Thank you received: 13652
14 years 2 months ago #16035
You need to set the option "URL where to redirect when the cart is empty" in the tab checkout of the configuration.
14 years 2 months ago #16041
That did it...thanks so much!
12 years 1 week ago #115876
Oddly enough I didn't think this would be the case because I had already unpublished ALL the content modules in the store. Ironically enough though they are all active apparently. I changed the "All Sub Elements" to "Direct Sub Elements" on the products listing menu item and voila...fixed. Why are unpublished things active and how come they affect things even when in this state?
~Wil
***NEED THIS BUMPED TO PROPER POST here--> www.hikashop.com/en/forum/4-how-to/42936...duct-list-twice.html or REMOVED. Thank you.***
Last edit: 12 years 1 week ago by responseit. Reason: Wrong Post. Opened several tabs, replied on the right one and it posted to the most recently opened tab.
