Hikashop Content module
13 years 8 months ago #22346
now I am a little bit frustated.
I will show the categories on the main page (that is working, not my problem). After displaying the categories on the mainpage I will have the possibility to click on that category and "land" on the products of that category.
But if I click on any category there I 'll get an error page...(I 'll get nothing if there are no products in that special category).
I've tried it with the Hikashopcontent module itself and I created a new one. It is always the same problem.
I am using joomla 1.65
Where is my fault?
  • Thank you received: 13533
13 years 8 months ago #22348
We need more information on your problem in order to be able to answer you.
What version of HikaShop are you using ? What error message do you have ?
Also, please activate the debug mode of the configuration of joomla and try again to display the page with the error. Do you get another error message ? Which one is it ?
13 years 8 months ago #22351
I am using 1.52 essential.
the failure message: 404 failure "website not found"... it is the same failure message under debug mode joomla.
the same category list via a "go to menu button" works well.
13 years 8 months ago #22352
404 errors are usually linked to SEF settings.
Do you have SEF activated on your website ?
If you deactivate it, does it work ? What are the URLs of the not working page in both cases (with and without SEF activated) ?
13 years 8 months ago #22353
I have no SEF activated right now - outside the joomla standard (so there is no difference)
(meanwhile I have updated to Joomla 1.66)
Here are the "URL" (I can send you the full one direct if you need them)the first one is my problem with the 404 failure (module positioned on the side) the second one is the same but configured via Top-Menu (zum-shop) and working:
www.xxxxx.xx/index.php/category/listing/...systeme-absetzbecken
www.xxxxx.xx/index.php/zum-shop/category...systeme-absetzbecken
What is the problem?
13 years 8 months ago #22354
These are SEFed URLs so you HAVE SEF activated on your website. Please provide the unSEFed equivalent of these URLs and see if it works when SEF is deactivated.
As I said, the problem probably comes from the SEF settings
13 years 8 months ago #22356
if the SEO optimization (userfriendly url) is deactivated it seems that it works.
sorry I misundertood SEF /SEO
13 years 8 months ago #22359
And what are the URLs once unSEFed ? It should still work with SEF activated but the settings need to be correct. Having the non SEFed version of the URLs might help us understand the problem...unless you're fine with not using SEF (which doesn't matter much in terms of SEO).
13 years 8 months ago #22360
here is the url
www.xxxx.xx/index.php?option=com_hikasho...etzbecken&Itemid=513
I can work with it, but I would prefer having the SEO option again
Last edit: 13 years 8 months ago by ecodiver.
13 years 8 months ago #22365
The URL is good. We can't conclude anything from that.
Maybe with screenshots of the hikashop options of the module, the menu attached to it (id 513) and the associated module of that menu, we might find somehting...
13 years 8 months ago #22377
I have attached the two pr_sc of ID 513 in a word file. Hope this is ok. Ordering field is "ordering"
13 years 8 months ago #22379
wrong word format
File Attachment:
File Name: hika_probl..._07_.doc
File Size:1,698 KB
13 years 8 months ago #22383
Mmm. I see two modules in your screenshots.
Normally, you should have:
1 module displayed the categories listing (I see that you have it already).
1 menu displaying categories. That menu should be selected in the module above mentioned in the menu option.
1 module displaying a listing of products. That module should be selected in the menu above mentioned in the associated modules option.
In your case, I see that your menu is displaying products and not categories and that there is no products listing module attached to it.
If you create the first module as explained in the tutorial www.hikashop.com/en/support/documentatio...splay-front-end.html the system should create automatically the menu and second module with the good parameters. Note that with HikaShop 1.5.3, we improved that process so you might want to update first if you have a previous version before trying that.
13 years 8 months ago #22404
I have made the update on 1.53 and everything with the SEF is working fine.
Thanks for that. Your support is really brilliant!
  • Thank you received: 17
13 years 8 months ago #22422
I have 1.5.2 installed and when selecting Update/about it says I have the leatest stable version : 1.5.2, should it update to 1.5.3. If so how do I get this new file.
thanks.
13 years 8 months ago #22430
The update is not yet downloadable via the update menu of HikaShop as we are waiting for feedbacks before rolling it out. If you want to update, you can download it directly on our website. It is available on the download page for the Starter edition and on your order details page for commercial editions
