[SOLVED] : breadcrumb trail for cats in products
  • Thank you received: 17
12 years 9 months ago #37620
Hi.
I have a sugggestion which has bugged me for quite a while.
I have products located in different categories, this is one the the great things about hikashop how you make the product then just link it into as many different categories as you like. Theres is one problem though.
An example is needed :)
If I have a category called
Leisure..liferafts...Accessories
and another category called
Commercial..liferafts...Accessories
The base products (liferafts) are different but the accessories are all the same, so good old hikashop makes this very easy for me to link the accessories to both categories, excellant ! BUT on the category list they look identical :( yes I know there is a ID at the end, but tbh that doesnt really realte anything to me in the real world as I dont know the IDs :)
Last edit: 12 years 5 months ago by rikatos.
The following user(s) said Thank You: uteco
12 years 9 months ago #37662
I definitely subscribe to this! I logged in to make this same suggestion, just to see it rikatos beat me to it! :) Shouldn't really be difficult to implement I guess?
  • Thank you received: 4028
12 years 9 months ago #37664
In order to summarize and understand, you want that the name displayed in the category listing (your screenshot) contains the "full name" ?
Like: "Leisure / liferafts / Accessories" instead of "Accessories" ?
Last edit: 12 years 9 months ago by Jerome.
12 years 9 months ago #38000
Yes, that would be great to be able to identify the correct category when multiple categories with the same name are selected.
Thank!
  • Thank you received: 13373
12 years 9 months ago #38070
It's in the todo list.
12 years 9 months ago #38090
Sorry took so long to reply, yes nicolas, exactly that :) and thanks for putting on the to do list :)
Last edit: 12 years 9 months ago by rikatos.
12 years 7 months ago #48153
Hi there
I was just checking back on this to do. I am now in need of this quite bad as my shop has 6 main categories with subcategories that could all be the same name ! it is difficult to know which of the sub categories is one to remove or add at the moment.
12 years 7 months ago #48222
We'll look at that for next release
The following user(s) said Thank You: rikatos
12 years 7 months ago #48237
That's good news! We're also waiting for this... :) Thanks!
12 years 6 months ago #48243
Aye it is :) I am so looking forward to it, kinda sad really !
12 years 5 months ago #52763
marked as solved as its implemented in the latest hikashop, and its all I ever wanted so THANKS guys :)
