double voting at products
13 years 3 weeks ago #45537
Hi, I activated the voting system, and in either configuration I get 2 groups of stars.
I t must be a small thing, but in the configuration i am not able to get rid of the second group of stars.
i attached a screenshot
Best regards,
Roy
  • Thank you received: 13533
13 years 2 weeks ago #45655
Could you do a screenshot of the vote tab of the configuration so that we can try to reproduce the problem ?
13 years 2 weeks ago #45731
here is my screenshot:
13 years 5 days ago #47149
Hi rockoladeluxe,
This problem have been corrected recently, it come from the name and the id for the vote module which are the same.
So some explorer don't make the difference between the both, that's why the stars of the comment module are called at the same time than the stars of the vote module.
In the next release this bug is corrected, but you can correct it by yourself if you want.
It involves some modifications.
Edit the file: YourSite/component/com_hikashop/views/vote/tmpl/form.php
Change:
echo "<select name='hikashop_vote_rating' id='hikashop_vote_rating' style='display:none;'>";
TO
echo '<select name="hikashop_vote_rating" id="hikashop_vote_rating_id">';
And edit the file: YourSite/administrator/component/com_hikashop/classes/vote.php
Replace all the:
TO
Last edit: 13 years 5 days ago by Xavier.
13 years 5 days ago #47158
Hi Xavier,
thanks for the anwser, I'm working with Firefox11 and Chromium for Ubuntu 11.10.
I did the changes then cleared my cache but the double voting is still here.
13 years 5 days ago #47159
Hi Xavier,
I did the 2 changes you described and then cleared my cache but the double voting is still here...
Thanks,
Roy
13 years 5 days ago #47164
We are going to correct it.
If you only use the vote system and no the comments.
Try to comment the line:
echo hikashop_getLayout('vote', 'form', $params, $js);
In HikaShop > Display > Views, edit: product / show.php or (show_default.php) it depends of your version of hikashop.
Time to create page: 0.138 seconds
