[SOLVED]Problem with Alpha User Points
14 years 3 months ago #53986
Hello
I am using for some time Alpha User points and everything has worked correctly.
But since the last update I have a problem, when I change the order to "Sent" items that the user has won with the purchase lose points.
For example, if a user makes a purchase and wins 10 points when I change the order to "Shipped" these 10 points are removed.
What is the problem?
Screenshot: awesomescreenshot.com/08282knd2
Screenshot plugin Hikashop AUP: awesomescreenshot.com/02282ky58
Thank you.
Andreu
Last edit: 14 years 3 months ago by diosneptuno.
  • Thank you received: 4078
14 years 3 months ago #53995
There is an option in the AlphaUserPoint plugin named "Gives Points on statuses".
In this field you have to list all valid statuses. If the order change to a status not listed, points would be removed.
When this field is empty, the plugin would just retrieve the "order confirmed status" from the HikaShop configuration.
My recommendation is (for a classical configuration): confirmed,shipped
The following user(s) said Thank You: diosneptuno
14 years 3 months ago #54033
Thank you very much, I had not seen this option.
Problem solved
Fantastic support!
Andreu
