Show cats and products in HikaShop in a cool way!
12 years 10 months ago #54345
Hi guys,
Skyline HikaShop Nested Accordion is a module of Joomla! that displays HikaShop categories as multilevel accordion menu. The accordion effect is written in native mootools javascript which is supported by Joomla! core so that there will be no javascript conflict when you use this module.
Try this here .
Thank you.
Last edit: 12 years 10 months ago by Hoang.
  • Thank you received: 13533
12 years 10 months ago #54375
That's great !
Thank you for sharing that !
12 years 5 months ago #73243
is there any way to sort the catagories in alphabetical order????
12 years 5 months ago #73247
In hikashop categories listing modules, you can go in the hikashop options of the modules and select the ordering column and the ordering direction options for that.
12 years 5 months ago #73248
Thanks Nicolas but i tried that and this is related to the Skyline Accordian Menu so probably not your area of support
The module installs fine but the category name order is out sync
$query->select('a.*')
->from('#__hikashop_category AS a')
->join('INNER', '#__hikashop_category AS b ON a.category_left BETWEEN b.category_left AND b.category_right')
->where('b.category_type = \'product\'')
->where('b.category_parent_id > 1')
->where('b.category_published = 1')
->order('a.category_left , a.category_ordering ')
12 years 5 months ago #73249
You shoudl change:
->order('a.category_left , a.category_name')
Last edit: 12 years 5 months ago by nicolas.
12 years 5 months ago #73250
Thanks again but i tried that and it did not work.
see attached. I have raised a support ticket with Skyline a few days ago but they are not as quick with giving support as you are :)
12 years 5 months ago #73251
Than I don't know. You'll have to wait for their answer.
The following user(s) said Thank You: ponygirl
